Zachary said:I would not recommend letting your fuel go that low because all of the crud in the bottom of your tank will go through the injectors and potentially cause problems.
:iagree:Mr.yoshimura said:I have gone over 25 miles after the range reach 00! and manager to get get 22 Gal in the tank at fill up. i think the curd would have 2 go trough the fuel filter first b4 it reach your injectors.
I'm not saying it does flash, I'm saying it should. I'm sure there is at least another 50 miles left after the computer reads zero for legal reasons. I would never run it this low however because even if there isn't any crud in the tank you can still run the risk of burning up your fuel pump.mainer said:They yellow fuel light was on, but not flashing. That makes me wanna get it flashing. Now i'm going to have to run it down again. How much do the tanks hold?
Coop
NCSCOTT said::iagree:
I changed a fuel pump in a 2000 Grand Am 3 weeks ago w/98k miles. The kind that is in the tank. Had to drop the tank to get to it. This was my sister-in-laws car and she has never care where she got gas from. There was minimal debris in the tank. It was like a spec here and there. Not even worth draining the tank to remove. Plus the strainer on the intake of the pump would have caught 99% of that what was in there.
Unless you have just got into some nasty gas or your tank is corroding from the inside out the chances of getting anything to your injector past the pickup screen and fuel filter is minimal from my experience.
I have run my 4Runner down to 0 and beyond a number of times and regularly run it down into the teens and have never put more than 22.5 gallons in the 23 gallon tank, and I top of the tank every time in every vehicle I have ever owned. Not all the way into the filler neck but 1-3 gallons past where the pump clicks off. Never had a problem with the fuel systems.
Has the fuel economy number stated by your computer dropped? I'm pretty sure the computer just takes your average fuel economy multiplied by the estimated volume of fuel in the tank to get the number for range. The longer you go without resetting the fuel economy number, the closer to "acutal" it is (not that its giving you a correct value, but it will level off at some number based on your driving habits).Falls said:I've run mine down to about 10 and it took 21.5 gallon's and alot of cash to fill it. I use 2 full tank's a week on my truck.
You know when I got my 4R I would fill it and the range would show like 310-320 but now I fill it and it show 295 pretty consistantly , wonder why that is ?????
Here is where the V-6 vs V-8 begins.....Falls said:I've run mine down to about 10 and it took 21.5 gallon's and alot of cash to fill it. I use 2 full tank's a week on my truck.
