How low can you go?
mainer
So how daring have you been? How low have you taken your miles left # in the info center? Had mine down to 4 miles left. She took 21.9 gallons at the fill up.
COop
I've had mine in the single digits before. What worried me more though was the fact that I could see about 1/16" of daylight between the bottom division on the fuel guage and the top of the needle, almost resting at the 0V position. The yellow light should flash at that point.
They yellow fuel light was on, but not flashing. That makes me wanna get it flashing. Now i'm going to have to run it down again. How much do the tanks hold?
Coop
I would not recommend letting your fuel go that low because all of the crud in the bottom of your tank will go through the injectors and potentially cause problems.
Yeah I hear ya. That day I left my wallet at home and I had to make some long unexpected trips. Now I keep a spare wad of cash in the car in the event it happens again...
I have gone over 25 miles after the range reach 00! and manager to get get 22 Gal in the tank at fill up. i think the curd would have 2 go trough the fuel filter first b4 it reach your injectors.
:iagree:
I changed a fuel pump in a 2000 Grand Am 3 weeks ago w/98k miles. The kind that is in the tank. Had to drop the tank to get to it. This was my sister-in-laws car and she has never care where she got gas from. There was minimal debris in the tank. It was like a spec here and there. Not even worth draining the tank to remove. Plus the strainer on the intake of the pump would have caught 99% of that what was in there.
Unless you have just got into some nasty gas or your tank is corroding from the inside out the chances of getting anything to your injector past the pickup screen and fuel filter is minimal from my experience.
I have run my 4Runner down to 0 and beyond a number of times and regularly run it down into the teens and have never put more than 22.5 gallons in the 23 gallon tank, and I top of the tank every time in every vehicle I have ever owned. Not all the way into the filler neck but 1-3 gallons past where the pump clicks off. Never had a problem with the fuel systems.
I thought we discussed previously that there is approx. a 2 gal diff. between when the range reads 0 and when you will run out of fuel. But from some of the observations in this thread that doesnt quite make sense.
Coop
I'm not saying it does flash, I'm saying it should. I'm sure there is at least another 50 miles left after the computer reads zero for legal reasons. I would never run it this low however because even if there isn't any crud in the tank you can still run the risk of burning up your fuel pump.
NCSCOTT said:
:iagree:
I've been told the crud is not the problem, but condensation and cooling is. More air = more moisture. The liquid helps to keep the pump cool.
I've run mine down to 20.7 gal.
I have gone down to 2 miles left on the display. It took 20 gallons to fill it up.
I replaced my fuel pump in my Jeep two years ago. After dropping the tank, with 160 k miles on her, there was nothing inside the tank as far as crud. I wiped the inside down with paper towels. The towels came out slightly discolored but that
I've run mine down to about 10 and it took 21.5 gallon's and alot of cash to fill it. I use 2 full tank's a week on my truck.
You know when I got my 4R I would fill it and the range would show like 310-320 but now I fill it and it show 295 pretty consistantly , wonder why that is ?????
Has the fuel economy number stated by your computer dropped? I'm pretty sure the computer just takes your average fuel economy multiplied by the estimated volume of fuel in the tank to get the number for range. The longer you go without resetting the fuel economy number, the closer to "acutal" it is (not that its giving you a correct value, but it will level off at some number based on your driving habits).
Here is where the V-6 vs V-8 begins.....
My V-6 Runner usually reads about 380-400 range after a fill up. I filled it up just today. I reset the mileage meter every time. The new range was 392 miles. I checked when I got home and had driven 28.5 miles and the remaining range was 357. The difference between what I actually went and the range remaining was only 5 miles. I account that to the oversized tires and agressive driving on the way home from work. Before the increase in tire size it would always read 395-420. The calculated mileage on the tank today was 17.43 mpg, the 4Runner said 19.3 mpg. 17.89 gallons and 312 miles. The remaining range was about 50 something. I actually filled up before E this time. Wife needs the Runner tommorrow. :mad:
