How low do you go? 5th Gen Off Road Tire Pressures
Canazes9
I'm just curious what some other members are running in their 5th Gen when driving in off road conditions. I apologize if this is a repeat, didn't see it on a quick google search.
1) What's your normal trail pressure?
2) Will you go lower? Min?
3) Tire size/rim?
4) Have you lost a bead?
Here are my answers:
1) What's your normal trail pressure? 15psi
2) Will you go lower? Min? I have gone down to 12psi a couple of times. I'm beginning to think this will be my new standard for technical trails. I've never gone lower on the 5th Gen (no need yet). I suppose if I was stuck I would try as low as 8psi (obviously, I would try 10 first...)
3) Tire size/rim? Mickey Thompson MTZ's LT265/70R17E on stock 17x7 SR5 rims.
4) Have you lost a bead? No, not on the 4Runner.
3) Tire size/rim?
1. 18 psi
2. Yes, if I think it might be goopy/ uber technical. Probably wouldn't go below 12. If I get stuck that bad I can get a snatch from a buddy or (soon here) winch out.
3. 285/70/17 MT/R Kevlar on 17x8.5 SCS-6
4. No but looking at my numbers I play it pretty safe.
1. Deflators are set to 18
2. Yes. For technical trails, I go to 12psi. I have gone as low as 8psi to get flotation in deep snow, it worked
3. 285/70/17 Duratrac, 17x8 (I think) ATX Mojave
4. No, but I do carry the equipment to reseat one
At 12 psi in rocks, I have seen my tires deformed to the point I was sure they were going to pop off the bead. I don't think I would run any lower in rocks without beadlocks.
Summer tires
1. 12 psi
2. No
3. 285/70/17 E load GY MT/Rs on 17x8.5 SCS Stealth 6s
4. Not yet... (knock on wood)
Winter tires
1. 18 psi
2. I might go lower in deeper snow. Maybe 15 psi
3. 285/70/17 E load Nokian Rotiiva AT on stock TE wheels
4. Not yet...
Couple of things I'd note. First, if you're running a P-rated tire, going much lower than 18 psi is risky. Start high, see how it feels, then go a little lower if you feel you need to - way easier to let more air out on the trail than to get the compressor out. Adjust your pressure based on your overall weight - if you're completely loaded up with people and camping supplies you may not want to go as low as you do when running completely empty.
Dead blow, starter fluid, and a lighter? :gun4:
Seriously tho (I have done it way) what have you got?
Method 1: ratchet strap and dual compressor setup that should deliver enough CFM to set the bead.
Backup method: Propellant from an aerosol can:target:
1. 15psi
2. 12psi for tech (been as low as 10 in deep powder)
3. 285/70/17 KM2 on Konig Countersteer type x
4. Nope
Have been down to 12 but usually 15-18 Depending where I am.
Won't go lower.
Stock rim with Cooper AT3's.
Not on this rig, but I do carry ratchet straps, starting fluid, compressor and other ideas.
I mark my tyres in case I spin them.
1) What's your normal trail pressure? Deflators are set to 14psi. I've never required anything lower than this with my tires.
2) Will you go lower? Min? I know a few guys who run lower and don't seem to lose beads. I may try as low as 12psi in the future.
3) Tire size/rim? 285 70 R17 Mickey Thomson Baja ATZ Load D / Stock SR5 17"
4) Have you lost a bead? Not yet
Deflators- 18 psi
Bare Min. - 15 psi
Tire - Bridgestone Revo II AT 265/70/17 LT
Never lost a bead.
When going purposely off road, I carry my Puma 12v compressor. I always have a tire repair kit, starting fluid, MV-50
1) What's your normal trail pressure? From 37 psi (normal road) to 20 psi.
2) Will you go lower? Min? Sure but not below 15-18 psi. I run "P" rated tires.
3) Tire size/rim? 265/70/17 Stock TE rim
4) Have you lost a bead? Not with a 4Runner.
Philthyphilthy
