They all differ to some extent. My eyes were above the roof on my 2002 before my lift, and I'm 6'1. So that's 73 inches. After my lift I could no longer see directly over the roof. And I'm getting 33's installed right now so my roof should be at around 77" as a final measurement. Are you trying to see if your truck will fit in a garage?
Stock? To many other variables. As copied from KBB.com for a 99 4 Runner can vary an inch or two with different wheel option and of course with any lift all things are out the window. My truck with the lift in my signature block and the Baja Rack is 6'10" or 80". I know becasue the car wash I go to has a 7'0 limit and they came out and measured to verify before they let me go through.
Dimensions & Capacity Details
Fuel Capacity 18.5
Wheel Base 105.3 inches
Overall Length 183.3 inches
Width 66.5 inches Height 67.5 inches
Curb Weight 3440 lbs.
Tires / Wheel Size P225/75R15
Rear Tires / Wheel Size -
Turning Radius 38.1
Standard Axle Ratio 3.91
Maximum Ground Clearance 9.8
Maximum GVWR 5250
Maximum Towing 5000
Payload Base Capacity 1320
Head Room: Front 39.3 inches
Head Room: Rear 38.7 inches
Leg Room: Front 42.6 inches
Leg Room: Rear 34.9 inches
Shoulder Rm: Front 53.6 inches
Shoulder Rm: Rear 53.3 inches
EPA Passenger -
EPA Trunk or Cargo 79.8 cu.ft.
