How to change climate control bulbs 2005 Sport
terrihight
Can somebody tell me ~ How to change the climate control panel bulbs in a
'05 4 Runner Sport? Well at least I think that's the correct way to put it!
There's no light in the panel that says your range and temp. etc...
I can't seem to find much info on it. Help Please :)
there is a link on this site that has on how to replace the bulbs i had to do it myself and you can only get the bulbs from the dealer they run around 4 dollars..i'll try my best to explain how..first you need to open up the capartment that is right below your controls for the fan and ac the three dials anyhow need to pull the capartment door off comes right off just pull up on it then look in and you will see that one screw that sets in the center top take it out.then you will need to take hold of the unit this sounds a little crazy but this is how its done pull on the unit and it will onsnap from bottom and top and when you have it you will be albe to see the bulbs in the back of the unit and again the dials and the display unit for ac gas temp control is one unit..you will need to take the bulbs out and take with you to the dealer......let me know after you change out..
