how to hardwire a radar...
91bulldog
Can someone help me.
I just bought a v1 radar... How do you remove the overhead? does it just pop open?
Which is the best wire to tap? a wire that only gets power when the car is on...thx for the help..
Looking for the same info, I'll tag along for a reply. But, I'm looking to put it low on the dashboard and run it to the fusebox under the steering colum maybe? Any help would be appreciated.
i just popped the console out of the sunroof -- be carefull to not break the clips or loose them -- they tend to go flying.
I tapped directly into the light power -- it is NOT switched
if you can find one that is only one when the key is on - let me know so i can rewire mine!
If you can find the sunroof motor power, that should be switched and should work for power. Get a tester to make sure if you don't want to splice into all the wires.
I have a remote display so I was able to get power from the center console.
