how to lower rear hatch window manually
blazinjames
so I tried searching with no luck
got a 91 4runner I need to lower the rear hatch window manually...
I pulled off the cover and have window regulator/motor assembly exposed. I am just not sure the best way to get the window down?
are there some bolts I can get to get the window down?
thanks
Take the plug off of the motor and run 12v directly to the motor. 12v going in one way will raise the window and 12v going in the other way will lower it.
Have you tried to figure out why your window switch isn't working?
the motor isn't working. I need to lower the window so I can take the tail gate off before I send my parts runner to the scrap yard
Mike Sargent
