TOYLUVA
So I instaled my daystar 2.5/1.5 last week and what a breeze even with XREAS. Easiest lift I ever installed by far {thanks to the info found on this site}. But what I wanted to share was if you want yours to be perfectly level you know that the difference in fender height and tube step or nerf bar height . To make a long story short, the rear spacer from daystar actually measures 1.5625" of lift. well I installed the front spacers first and that brought all {4} my fenderwells to 35" exactly from the ground. but my nerf bars were 1/2" higher in the front...ugly. So I went to the local machine shop and this is what we did. First we made a crush ring to fit in the coils spring slot of the spacer. This allowed the jaws on the lathe to get tight. Then we cut .7006" off the top of both spacers. Then we shaved the outside at 14 degrees down to the original o.d. of the spacer. The shaved the inside of the spacer at 10 degrees to the original i.d. of the spacer. this left me with .86 " of lift and the outside fit in the upper coil spring perch nicely and the bumpstop was a litle tight on the inside but fit. Now I am left with 35.75" height at the rear fenders and 35" on the front fenders. Nerfbars are about 1/8" to 1/4" higher in the rear and man am I pleased with that. Beautiful and my 265/70 17 nitto tg's fit perfect other than only 3/4" between tire and upper control arm was a little tight. all in all the lathe took about 1hr to cut the spacers and the lift was installed in under 3 hrs total. 2hrs front 1 hr rear.:guitar2: Hope this helps someone with the same intrest in making your runner truely level and maybe even ya'll who have it at 1.5 and would like to remove the spacers and actually make the runner level. I have pics and more measurements if needed so let me know. I will do my best to help.
