cv4runner
What year is your T4R?
2006 SR5. I bought it used with only one key. I've been paranoid about losing the one key I have so it brings a lot of peace of mind to have a spare just in case.
Today I realized my new key has one draw back; it doesn't lock my glove compartment. Has anyone else had this problem with their aftermarket key?
Cvrunner: is the extra key you bought oem? The one I bought from amazon said nothing about being oem and looks much cheaper too. Did I miss something, are the keys from the amazon link supposed to be oem?
Unfortunately this process didn't work for my 4Runner. I purchased the key off of eBay from the links provided in this thread for $8, Had the local ACE cut it for .99cents. Tried the process listed above and thru the .pdf provided and had no joy.
I performed the process as described and never got the solid immobilizer light. As soon as I pulled out the Master Key, the immobilizer light blinked every time. Tried the process at least 6 or 7 times.
Any help would be great. I did look at my CarFax when I bought the truck and noted that there was a re-programmed key about a year after the initial purchase of the vehicle.
It's definitely the same color as my original. After a close examination, I noticed the groove (just off center) that goes down the length of the key on both sides appears to be a bit wider on the new key opposed to a thinner groove on the oem key. Other than that everything else looks identical. I'll try to upload a picture from my phone so you all can see what I'm talking about.
What are the procedures for doing a full erase?
I want to avoid, NOT being able to start my truck with the Master Key if I do this.
nicolachel-
I went back thru and re-read your original post,... JOY this time! :girl:
I found out what I did wrong, too. I inserted and removed the Master Key 5 times (5 complete cycles), meaning I REMOVED the Master Key on the 5th time, instead of leaving it in the ignition after the 5th insertion. Therefore, there was a 6th insertion of the Master Key.
Anyway, this process does work! I guess, I was just a bonehead :moping: because the Service Bulletin I downloaded wasn't clear to my readings of it.
Can't complian now at all. For under $10 dollars, this is a good deal. Now I need to find a place to hide the new key and blank one!
Congratulations!
I actually did the same thing (remove key on the 5th time since the pdf says "insert and remove") after reading the pdf, that's probably the reason for me to open this thread (to provide a clear description of the procedure for those in need).
That does not seem to be the problem, my keys bought off amazon also have wider grooves but they lock/unlock the glove box just fine.
I guess that the grooves are just used to mechanically strengthen the key itself(so it's not easily bent/twisted), but that's just a guess.
You want to talk to your locksmith about this.
1. Take the new key and one master key that can start your 4runner(old key) into the 4runner with you and close the driver's door.(immobilizer light should be blinking)
2. Insert old key, remove old key, Insert old key, remove old key,
Insert old key (immobilizer light should be off from the first insertion)
3. open and close driver's door six times (immobilizer light should be off)
Step 2 and 3 need to be done in less than 35 seconds(pdf says 35 seconds)
4.remove the old key. (immobilizer light should come on(steady on, not blinking))
5. insert the new key(immobilizer light should be blinking)
Then just sit there and wait, after about one minute the blinking immobilizer light should go off and you're done.
