How to purposely break off a weldnut?
capri_auto
I drilled out some broken skid plate bolts in order to retap. I butchered one on the trans skid. I drilled through the side of it somehow. Its the front, driver side, weldnut on the trans skid and there is a nice access hole right next to it. I want to break the whole weld nut off and install an M10 rivnut in its place. Any tips on how to break it off? I dont have an airhammer.
Once it’s drilled out a few strategic blows with hammer and punch should do the trick. Aim for where the welded nut makes contact with the frame. It should pop off pretty easily. I did the same with M8 rivnuts a couple years ago. Been holding up fine since...
My first choice would be a Dremel with a thin grinding bit, less likely to gouge out excess material than a full grinder. If there's no room for that, a cold chisel and hammer, aimed to work its way under an unwelded seam if there is one. If that fails, try a bigger hammer until it works
I ended up knocking 4 of the weldnuts out with a punch and hammer. The ones on the radiator support took a lot of persuasion bit I got them all out and put m8 rivnuts in using the bolt and nut method. Replaced the bolts with grade 8 flange bolts and applied anti seize. Good as new and all the bolts are the same now. Pain in the ass factor was high.... end result was worth it.
Ambrose67
