How to remove driver's kick panel and footrest in a 2006 4R?
arcas
This might sound like a dumb question but...how does one remove the driver-side kick panel in a 4th gen 4Runner (2006 specifically)? If the driver side is anything like the passenger side, the panel is held on by a couple clips and a screw. On the driver side, however, the footrest is blocking access to the screw. So I think if I could remove the footrest, the rest should be cake. How is the footrest attached? I've tried prying in hopes that it was just a clip or two but it barely budges. I'm afraid I'm going to break something if I pry harder.
I've read several threads that involve running new speaker wire through the door grommet and none have mentioned any difficulty accessing the grommet opening behind the panel so I have to assume that I'm making this more difficult than it really is. :confused:
Thanks.
Following up my own post. I gave it a couple hard tugs and it came up. It uses some pretty stout clips. I'm glad the other molding and dash clips aren't as strong.
Just yanked out my footrest and now I'm deciding how to cover up the area. Did you buy a larger floormat or did you append your existing one with extra carpeting?
Neither. I replaced the plastic footrest when I was finished. Had to unscrew the clips a bit and mashed down with my foot. Took a few tries but it finally snapped back in place.
BTW, for floormats, I use cheap outdoor carpeting from Lowe's instead of messing up the expensive factory mats. It's not a perfect color match but it's close enough and at $2/yard or less (I can't remember) I don't have to worry about me or my passengers messing up the factory mats.
Nice - yeah, I just stopped by Home Depot myself. Picked up some black rubber mat which I placed over the opening and under the carpet (after cutting it smaller.) Taped that puppy in place with some electrical tape. Next, bought some grey-ish commercial carpet and velcroed that onto the factory carpet.
My first 'mod' and it only cost me $4.50...now my left leg can finally rest comfortably.
