Put the boxed end of the wrench on the nut, open end out, then use another wrench boxed end in the open end for leverage
Yes, ratchet wrench. You can get a cheap set at Harbor Freight if you don't wrench much...
Ha. Atman got bored. Wandering all the way to the 4th Gen section like this :bounce:.
Just picking lol. I follow your build pretty regular. Origionally looking for cross-generation ideas. Love your truck. Keep up the good work. (And best of luck in the water! It's that time of year again!)
The right tool for the job makes all the difference. A ratcheting wrench can help, also once I put on extended studs to enable use of top plate spacers I found that I had to bend the sheet metal back a little bit to get the wrench over the top of the stud. When I put the 1" body lift on I instantly gained lots of extra space there. Sounds like you got it figured out already though. :guitar3:
