How Vulnerable is my Fuel Tank?
patkelly4370
I live in northwest Arizona desert. Very rocky.
I haven't scraped front of fuel tank skid plate yet. But I'm getting closer as I learn the capability of my 4runner.
My noob thinking is that the fuel tank is more vulnerable than the front, about as vulnerable to damage as the rear bumper. But the fuel tank is more vital.
Which did you impact first? Which have you impacted more often? Which impacted the hardest?
My intended use is daily driver and weekend "overlanding". Not looking to break it every weekend. But learning the limits for now.
Hey Pat, check out this thread as it has some discussion on what folks thought on which skid you should get first
Which armor first! (Based on likely impacts)
Also, [MENTION=306890]MAST4R[/MENTION] drives all over Arizona so he could guide you in the right direction.
I personally find that i scrape the fuel tank skid more than impacting it. Usually happens as im going over bumps that my breakover angle doesnt like.
Great question!
Here are my hits in terms of frequency and damage to plates:
1/ Front 3/16 RCI completely caved in. BUT the reason is speed. Frequent contact with no damage to the thick steel skid otherwise. VERY frequent contact on stock suspension. Lift alone is not the solution, I have 1" all around and stiffer springs, which is the solution.
2/ Rear LCA skids. Maybe not more frequent than #3, but are those hits hard when they happen. It is virtually exclusive to the pax side.
3/ AT and TC skids when sliding, dragging over stuff due to lack of brakeover angle. No damage at all, but relatively frequent use.
4/ Front edge of gas tank skid. I have had two very heavy hits there, everything else the stock skid could have held up to. As [MENTION=362200]SpeedyKevin[/MENTION] says, sliding, mild dragging is much more common than serious hits underneath the gas tank skid. Maybe if you do the Rubicon. Because I realized in time that the edge takes the beating, I went with Shrock despite having RCI front skids. The RCI gas tank skid cannot handle big hits; there is a pic of someone who destroyed theirs near Moab.
5/ Rock sliders. I am still very unimpressed by having rock sliders on any trail short of the Rubicon. My only uses so far have been a function of having them (2.5+ inches of lost rocker clearance). The one time they "saved" me was the one time I did not bother looking because I knew I had them. I would have looked and chosen a better line without them. So for me, this is still an expense that has not proven itself. In fact, sliders can DAMAGE the rocker panel under the correct circumstances (body and frame flexing against each other during certain maneuvers).
6/ Rear differential skid. I bought one after mildly damaging the protector of the drain plug while backing up to let a Jeep pass. I am not terribly concerned about the rear diff but since I have everything else...
Other:
7/ rear lower control arms: I only had small marks on my stock ones but decided to take no chances. Not really an issue except when dealing with big steps.
I do not use A-arm skids. They have no functional purpose that I can fathom. Sure mine are all scraped but spray paint costs less and traps no mud or whatever.
Be very careful with the Transfer Case skid when driving over dry grass. It traps grass underneath the exhaust cross-member. I keep an eye and clean it as needed.
Hope this helps!
the stock skid is fine for what you need then
watch some of these vids, kevin has been on the stock skids for all of this:
https://www.youtube.com/channel/UCJSHfhZHP8-iChAVCrXWTyA
i've seen someone nail the stock skid hitting a rock much harder than anything you could call overlanding and all it did was dent the skid and tank a little, no leaks or anything. unless you plan on on really getting into rock crawling the stock skids will be fine.
if you feel like upgrading skids, i'd start in the front to protect the transfer case. rock sliders are also a good idea and what should be your first purchase, even on mild stuff your rocker panels are pretty exposed.
The skid I hit the most is the front skid, but I'm stock height. I just manage speed, so if it looks like I may hit I go slow so if it hits it's not a big deal. I eventually replaced my stock skid with an RCI aluminum skid and I'm upgrading to LFD skids since I haven't been too impressed with the RCI aluminum skid, but I'm a bit rougher on my truck than probably a typical weekend "overlander"
H.Sikina
