hvac knob lighting question
03V84R
Trying to figure out why the temp up and down arrows dont light up? Only the auto and fan arrows light up?? I pulled the controls and theres only 1 long bulb with an orange condom and its working. Any advice??
thaanks
Jerry
On my limited the arrows are lit by two small bulbs but non-limiteds have only one long bulb... Are you sure it's working? Did you try swapping it to another control (they all use the same bulb)
Im in a SR5. The bulb works because the auto and ac arrows(@ 9 and 3 o clock) work , but the temp arrows (@ 12 and 6 o clock)
dont??
thaanks
Jerry
there is no separate lights for up/down temp if you are talking about the back lighting. something must have come loose inside the button to block the light. all 3 are the same, a bulb in the center throws light in all directions.
you need to "carefully" figure out how to snap off the cover to see what is blocking the light
also the light bulbs are NOT all the same, the 3 hvac knobs and the "rec" and whatever buttons under them use the long lights.
the center display uses two short fat "socket" bulbs and the mode/next buttons use a short "skinny" socket bulb, as does the rear power window control uses the same bulb
also all those bulbs are not cheap to replace, they are something around $4-$6 each for them
i just replaced almost all of those on mine at toyotapartsdeal.com
Part No.: 90010-09019
BULB
$2.81 2 $5.62 - hvac knob/rec button bulb
Part No.: 90010-09018
BULB
$2.81 1 $2.81 - mode/rear power window button bulb
Part No.: 90010-09017
BULB
$2.81 2 $5.62 - LED display backlight bulbs
BULB
BULB
BULB
Yup ,the local Toyota dealer gave me the short bulb, which is the wrong one. That said I was confused to discover there was only 1 bulb for all the controls/arrows in the center knob. It wasent obvious that it could be disassembled to see if something came loose inside. Ill try again later tonight.
thanks for the advice and part numbers!
cheers
Jerry
