Here are a few things I've learned about Toyota's auto climate control that might help explain its behavior.
- Warm air comes out by the floor, and cool air comes out the dash vents. That's the most efficient way to run both - make the warm air rise so that the interior warms evenly, and similarly, make the cool air sink.
- The air conditioning compressor almost always appaers to be on, as indicated by the light on the A/C button. As long as the outside temperature is above freezing, the system will use the A/C as it feels necessary to help dehumidify the air. Even in the middle of winter, it will blow dehumidified warm air to try to keep the windows from fogging up.
- You can leave the system in "Auto" and press the defogger button. That will override the program and start blowing dehumidified air at the windows. Press the defogger button again to go back to regular operation.
- On warm days when A/C is necessary, the computer turns on recirculating mode at first because that will cool the car off faster - it's more effective to keep cooling air that you've already tried to cool, rather then fresh hot air. Once the engine is up to speed and the A/C is running at full capacity, it will automatically turn off the recirculating mode and go back to fresh air if you didn't press the button to force it to recirculate.
I've found the auto climate control to be very effective in deciding the best course of action without much intervention. Here in Chicago, we've got a saying that if you don't like the weather, wait 20 minutes. It's not always that goofy, but it's very common to change temperature by 20 degress or more in a matter of a couple of hours, or to have snow or rain while the sun is shining.
If you're not used to auto climate control, or it doesn't do things the way you would control the air yourself, then I know it takes patience to adjust to its behavior. My dad got a car with climate control for the first time in his life a couple of months ago, and he hated it at first. Once he got used to it, he found that it really doeswork most of the time. Basically, it does exactly what the manuals have told you to do with the knobs for years.
