July 11, 2005
Test Drive:
2006 Toyota Highlander Hybrid Limited
By Grant Yoxon
Photo: Paul Williams. Click image to enlarge
The only thing worse than sitting in rush hour traffic after a hard day's work is passing time by watching the trip computer. Boring, yes, but also distressing. The moment you enter the freeway and slow to a stop, the litres per 100 kilometres indicator starts rising.
It might was well be a cash register. With each tenth of a litre added, the cost of the daily commute goes up, and up, and up. And the hours spent earning the money to pay the cost of getting to work go up, and up, and up.
Frustrating.
But that's just the personal cost. The environmental cost increases significantly too. The more fuel your vehicle consumes per mile crawled, the greater the environmental impact will be.
It doesn't have to be that way.
Highway 417, which dissects Ottawa from East to West, is fairly typical of urban freeways anywhere in Canada. Twenty hours a day, the 417 - or Queensway as it is known here - moves traffic quickly and efficiently across the city. But at rush hour, morning and evening, things get slow, real slow. It is something to be avoided.
But one day recently, it was a trip we couldn't avoid. We drove, or more aptly, inched from Greenbank Road in the West end to Blair Road in the East, a distance of 17 kilometres, in heavy five o'clock traffic. The trip took nearly 40 minutes.
Fuel consumed: zero litres. Not even a decilitre, not an ounce, none, no fuel used.
We were driving the 2006 Toyota Highlander Hybrid, a mid-size SUV equipped with a gasoline-electric hybrid drivetrain.
The Highlander Hybrid is a "full hybrid" system, meaning that the Highlander Hybrid is capable of running in separate gasoline or electric modes, as well as one that combines power from both.
Driving in heavy traffic, and with a light foot on the accelerator, we found the Highlander Hybrid would operate exclusively in electric mode at speeds below 30 km/h, as well as at higher speeds when coasting or maintaining a steady speed.
The result, of course, is excellent fuel economy. The Highlander Hybrid is rated by Natural Resources Canada (NRCan) at 7.5 Litres per 100 kilometres in city driving and 8.1 L/100 km on the highway.
The Hybrid actually uses less fuel in city driving than on the highway, the result of more frequent electric-only motoring in the stop and go of the city.
In addition, the Highlander Hybrid meets Environment Canada's Tier 2 Bin 3 and is rated as a Super Ultra Low Emissions Vehicle (SULEV) by the California Air Resources Board. One of the most stringent emissions ratings in the industry, SULEV-rated vehicles emit 80 percent fewer smog-forming emissions than conventionally-powered SUV's.
Our own fuel consumption experience didn't come close to the government estimate, but at an average of 9.5 L/100 km for our week of highway and city driving, it was significantly better than a gasoline powered Highlander (rated by NRCan at 12.7 L/100 km (22 mpg) in the city and 9.0 L/100 km (31 mpg) on the highway), and way better than any mid-sized SUV we've tested in the past year, some of which slurped up fuel to the tune of more than 20 litres per 100 kilometres over a test week.
A little technology (maybe more than a little)
The Highlander's hybrid system - Toyota calls it Hybrid Synergy Drive - combines a gasoline-powered 3.3-litre V6 engine with a high-speed electric motor - actually, three electric motors.
The front wheels are driven by the V6 engine and a high-speed electric motor that produces peak torque of 247 lb-ft from zero to 1,500 rpm. This provides the extended electric mode operation during low speed and stop-and-go driving. Power from the gasoline engine and front electric-drive motor is distributed to the drive wheels via an electronically controlled continuously variable transmission.
There is also an engine-driven generator and a rear electric motor that can charge the battery pack, which in turn provides power to the electric motors as needed. This former also acts as a starter motor for the gasoline engine and controls the output speed of the transaxle. Power from the engine is directed to the front drive wheels and the engine driven generator by a power-split unit.
The Highlander Hybrid's V6 is based on the engine in the conventional Highlander but with significant revisions to promote smooth integration with the hybrid system. These include revised calibrations to the Variable Valve Timing with intelligence (VVT-i) and electronic throttle control systems.
The engine alone generates 208 hp at 5,600 rpm, while the high-torque front electric drive motor produces 167 hp at 4,500 rpm. Together the system generates 268 hp and provides the standing-start and mid-range acceleration characteristics of a V8.
The Highlander Hybrid also has on-demand electronic four-wheel drive (4WD). A separate 50-kilowatt electric motor provides up to 96 lb-ft of drive torque as required. Under normal conditions, the Highlander Hybrid operates in front-wheel drive mode to conserve fuel, but when additional traction is required, the system will automatically switch to 4WD mode. Using input from several sensors, the system's computer calculates the optimal torque distribution between the front and rear wheels to maintain optimum drive torque under all conditions. When additional traction is no longer required, the system automatically returns to front-wheel drive.
A 288-volt DC nickel metal hydride (Ni-MH) battery fitted neatly under the middle seat is boosted and inverted to 650V AC. The battery is charged by the hybrid system's motor-generators. Additional power to charge the battery is captured through regenerative braking. Kinetic energy, that would normally be lost as heat, is converted to useable energy whenever the vehicle coasts or the brakes are applied.
The power steering pump and air conditioning are driven by electric motors, allowing both to function when the gasoline engine shuts off. Steering is an electronic system, using a 42V DC motor and gear reduction system built into the steering rack housing to provide steering assist.
Test Drive:
By Grant Yoxon
Frustrating.
