atheris978
I know as part of the braking system, Toyota has something they call brake assist. I spoke with the dealer and they said it only work in emergency stops. From what I can tell, it seems to caluculate the speed at which you remove your foot from the gas and aplly the brakes. It then boosts the brake booster to a higher level. Only problem is that I seem to be a little quick to the brake pedal more often then non. Very frustrating. It sure works ! I can toss everything from the backseat to the dashboard in under .25 seconds. Anyone know of a way to disarm this ridiculous system. It also seems to take a full 2 seconds to return to normal braking after it is activated. Even more frustrating !
