I bought my 3rd gen a month ago with no service records
DeadbeatYota
Other than when it was due for an oil change. My question is what all should I go ahead and take care of to make sure it's up to date? I checked the fluid levels and all the belts and everything seems to be relatively new and in good shape. The problem is it randomly cut off today when I was going to make a left turn. No weird shakes or noises or check engine light, and it cranked right back up. Any ideas?
'99 SR5 V6 4WD
Read through the second sticky at the top of the 3rd gen page, this should answer a lot of your questions.
I would certainly change all fluids...working on the same thing right now. I will be redoing all the scheduled maintenance expect the timing belt to be safe. I had no service records.
Thanks guys. Any ideas on why it would just cut off like that? I never had any problems before and it made it home fine afterwards.
Make sure the battery connections everywhere are solid. I had an Integra that cut out on me once or twice when braking or turning for that reason.
Edzo
