Is it possible that I don't have an alarm system ?
(I have the little "Toyota security" blinking light next to the steering wheel)
It's possible that it was disabled during the installation of an aftermarket system. If you have a factory-installed system (there were 2 options), you'll know based on one of these two things:
1. Black box under the driver seat. Is it there? If so, you have the RS3000 or RS3200 dealer-installed alarm, and your remote will NOT have a rear-window roll-down button.
2. No box under the seat, but red light in dash above the HVAC controls. This would be the factory-installed alarm, which has a 3-button remote (lock, unlock, and rear window). If you have this one, here's how to test if it's working:
- Roll down driver window
- Lock all doors using the driver door switch
- Close driver door and wait for a minute or two (system arming)
- Then reach in the open window and pull up on the door lock itself.
- If the alarm goes off, it's working (duh). If not, it's probably been disabled in place of an aftermarket system. Check behind the driver side kick panel to see if any of the wires in there have been molested. Mine were.
Really, your remote should tell you which system you have. Also, does your ignition key have a big black "handle" on it? If so, you have a transponder key that works with the factory-installed engine immobilizer. If it's just a plain metal key, no immobilizer.
The instructions for programming will vary depending on what system you have...so let's get that straight first.
