I have a 1993 4runner blown head gasket help!
runnertank
I was told by a member that I have a second gen don't no much about these things I just wanted a little bit of help on were or how to do a 3.4 swap I like the truck it gets me through the woods pretty good its a 5 speed also some help or pointed in the right direction would be appreciated!
How did you determine you have a blown head gasket?
Generally repairing what you have is way easier than an engine swap. I'd look for a used motor at a self serve used auto parts place to put in while you did a rebuild an your existing one.
being it's a manual trans will help make the swap easier. You can use parts off you 3.0 to reduce cost of swap. Toyonly swaps for exhaust crossover pipe and there are several people that do harness work. DO you research on whom ever you pick for harness work if your not doing it yourself. Yotatech has tons of write ups and short cuts, just plan it all out before you tear into. We get too many people with unfinished swaps because it was way more than they were prepared for. Good luck
Thanks I need to be back on the road like asap so I'm thinking reman or used 3.0 so I can slap it back in and ride out and good suggestions on were to get a good or reliable motor from low miles too I'm in SC!
Philthyphilthy
