I have never installed a radio
Utopia
Thinking of ordering something from crutchfield. Double DIN. Maybe something like axxera. I have never installed anything like this. Is it really that difficult?
It's pretty easy if you plan it well. I am installing my second pioneer which I like. My four runner has a x4500bt, Toyota face plate, crux Swrty-61s and harness. I added a USB and audio panel jack on the truck panel. Very nice. See some posts on it.
Do I need a new faceplate. When I look at crutchfield they mention nothing about it. I see the harness for the wiring which they say hook into my steering wheel controls and use a factory harness so I am guess it just plugs in?
If your putting in a double din pioneer. This is the face plate to get. Crutchfield doesn't know about this and the Metra is no so good looking.
PZ365-35904
PANEL SET,RADIO RECE
It's a Toyota part.
Get a USB panel mount and an isimple is335 for audio 3.5 and a pac USB cable to the dash. You can see my mod in the pic. Grab a micro bypass and your set.
Mojav
By the way my pioneer video cable?? Is hidden in the small storage door under the climate control. I cut a hole for the cabling and use the Scosche magnet to hold the phone
Mojav
PZ365-35904
It's a Toyota part.
Mojav
Mojav
English man, English!
I'm a little too quick and brief. The pioneer accessory is a video cable that's 30 pin. And connects to the rgb connector on the x4500. The USB and audio are on the Toyota dash. See pic lower left. On the upper left is the phone mount from Scosche.
Hope this helps. The micro bypass is for playing video while auto is in motion.
Mojav
youll also need to purchase
the metra 40-uv 13 m to f antenna Y cable and 40 gm10 adapter to retain use of the radio and diversity antennas otherwise your reception could suffer. Also make sure to connect the "power antenna" leads from the OE and metra harnesses. The directions crutchfield will include in the package have these leads identified. Lastly your steering controls will need to be programmed with the aftermarket hu
Just finished installing my Pioneer 4100 NEX from crutch field. The customer service is excellent if you run into any issues with the install. Their instructions don't cover everything. I'd highly recommend getting this usb extension http://Rerii 2 Meter/ 6ft Dual USB Extension Panel Flhttps://www.amazon.com/dp/B00WF0D6KY/ref=cm_sw_r_cp_awd_6Qd-wb0F0Q67X
And the metra dash kit that crutch field offers was a pain. Go with the one shown above.
If you have any questions on your install I have a lot of extra diagrams and instructions that crutch field sent me. I'd be more than happy to share.
Curious about this...the aux cable in my friend's 4Runner doesn't appear to be working. Not sure how he'd troubleshoot that specifically while simultaneously replacing the stock head unit? Ideally we'd get both taken care of at the same time but the aux port, I believe, is wired into the compartment below the arm rest, so that could be tricky. He's tried adapters, different phones, etc., seems to be the aux port is the issue, but he plans on getting a new HU soon and not sure if it would come with an aux port on the face plate or if it's possible/expected that one would continue to use the factory aux port.
