I just want to run stock tires...
Philthyphilthy
Gents,
I have an 04 Sport model. It came with the Xreas suspension but it was shot when I picked it up. I had my local shop change out the suspension for normal Bilstiens front and rear. Tires are Open Country 265/70x17, I would swap them for BFG AT's. There's certainly no room for me to get chains on in the rear with mud flaps, and it rubs at full lock on the fender liner in the wheel well, pretty bad. I just want to run stock size tires on factory wheels and not rub in the front and be able to get chains on the rear. Do I really need a lift to do this?
Edit: Looks like these are "upgraded" Totota/TRD wheels. OEM but not original spec. I assumed Toyota would sell wheels that match stock specs. According to the internet the wheels shown below have a +4mm backspace and 3.66" backspace. The stock wheels have +30mm offset and ~5.43"–5.50" (138 mm) backspacing. Never really grasped the offset/backspace math so if someone can help me decode it would be much appreciated.
I went with some Michelin Cross Climates 265 60 r18 (my stock wheels were cooked and wanted the bigger rim for bigger discs). I can run radial chains with the mud flaps on. After 3 sets of big bouncy Nittos the 4runner rides like a passenger car now, very happy camper. Lifts for our trucks are too much (money, work..) for hardtoppers
What wheels did you go with? What was the offset/backspace? I'm more of a 40's on 15's kind of guy, I like big rubber. That said I just want this thing to not rub with the wheels pictured.
The link is a good one. To me it's counterintuitive, it should be called inset, not offset. 10MM more offset moves the centerline of the wheel 10MM more towards the center of the car, not the outside. If you take a wheel that has 10MM more offset than stock, add 10MM spacers, it will move it back to the stock location.
Philthyphilthy
