I now have my 05 V8 Limited
MacVay
Last week I finally took possesion of my new 05 4Runner V8 Limited. This is my first Toyota and I love it so far. I moved up from an 02 Pathfinder LE and although I was sad to see the Pathy go, I love this new truck.
Here are some of my thoughts and first owner impressions:
*I love the torque coming off idle, this is somthing my Pathfinder never had. It should make a big difference towing my boat as the Pathfinder could do it with no problems just a little more screaming and crying.
*The Stability Control is interesting, I took the truck into a parking lot to get more "Aquainted" with it. Nice. I wish you could turn it off though.
*The Traction control takes a little while to get used to. I works but the jerking and clanging and banging feel a little weird.
*I do miss the Memory Seats from the PF. Why?
*The Stereo is nice but I expected more.
*With the T3 the truck is so fluid with power delivery. The PF had an Electronic Clutch for this it worked well but there was always a slight delay which coupled with a rear LSD made the rear kick out first under hard acceleration in the slippery stuff. You could also catch it testing if the traction is back under acceleration which gives you a little rear end wobble again. The 4R is just all business.
* The pedal placement sucks for wide shoes. Thank god it is more likely you will hit the brake with the accel not the other way around.
*When the truck is cold and in fast idle you really have to keep your foot on the brake as it just wants to go.
* I love the std trailer hitch and 7 pin. All I have to do it get a 7 to 5 Flat for the trailer and I am cooking with gas, no rewiring a useless 4 pin.
* I can't get my Homelink to work with my Garage Door Opener. My PF Homelink worked and I tested with my Neighbour's Honda. I think mine if Fubar.
* The Airbag cover on the wheel sometime pinches the controls for the volume and makes then stick.
* I wonder what the 0-60 times are now with the new V8. Some mags listed the 04 V8 at 7.2, I wonder if that has changed.
Anyway, sorry to blab on. I am just really excited to finally get this truck after waiting since October.
Cheers,
Congratulations on your new 4Runner. I agree with you on many of things you listed. Memory seats are only found in a Lexus. The Homelink should work with your truck and I would bring that back to the dealer. Also, I never had the problem of my audio controls getting stuck. Good luck with the 4Runner!
Welcome MacVay
I had a 2001 Pathfinder, that I trader for my 04 4Runner V8 about 13 months ago. I tow a travel trailer and note that the V8 torque is ideal for hills, and the PF used to downshift a lot - not as much with the V8. I really like the full time 4 wheel drive - great for our Canadian climates. I have the SR5 and miss the standard heater outside mirrors on the PF. The only other issue is the seat rattle. In 13 months, no squeaks or rattles, something that the PF could not boast.
Happy travels!
Enjoy your new baby.
Yeah I miss memory seats too. I had a BMW so when you open the door with your remote, it actually set the seats, mirrors temp and radio where you had it. No idea why it is missing on the LTD 4R.
Search for Homelink on this forum, there is a thread on setting it up. I also had the same problem, you just need to reset it. Can't remember exactly but search here and you'll find.
Also have the dealer fix the steering wheel, no reason for the audio controls to get stuck.
Did you get a 2WD or 4WD?
ALso with the V8s most people found the performance and MPG improves after about 10k miles. You might want to consider to go to Mobil 1 syn after 10k miles. Lots of discussion on this forum about oil too.
Oh yes, welcome!!
It is a 4wd. I'm not sure they sell the 2wd here in Canada.
I was wondering about the Synthetic and I may want to go that way so thanks for the advise. I will looks for these posts.
I did reset the Homelink. It is done by holding in all 3 buttons for more than 20 seconds. I think it NFG. I will search for posts just in case I am missing something.
It is -30C (-22F) today and I did hear the famed Harmonic sound today while cruising to work at about 75 MPH. It was somewhat loud and this was first time I heard it. I hope this was only because it is freaking cold outside. I do not want to be in the disgruntled group with this problem.
Is this something they all do?
Cheers,
you can turn off the VSC by locking the center diff, not recommended in general driving.
you reset the homelink by holding down the two outside buttons only. there is a nice pdf posted on how to setup the homelink. Toyotadoodz posted it but it seems most of his posts disappeared, damn.
try this
http://www.homelink.com/training/hlmanual.pdf
I would switch over to syn (M1 seems to be the easiest and best) sooner in those cold temps.
What tires do you have on? I went from Dunlops to Bridgestone Revos and my balacing and vibration issues dissapeared. Grip improved too. The Revos are noisier than the Dunlops though, I never had Harmonic sound.
