Icon uniball UCAs
Sakums20
$450
Used icon uniball uca for
05+ Tacoma’s
03+ 4runner
Gx470
Fj cruiser
in good condition, comes with brand new dust caps, and washers. I bought it used to put on my truck, but went with total chaos uca instead. Located in 90808.
46b6e09e-948b-434f-8b2c-911d96ea6670-jpg.3753220
c4524b19-0953-46bd-8cc6-2e0014eeb95c-jpg.3753221
eae9e52e-cc3a-4db2-a32c-b60766d16f59-jpg.3753222
3a65ecb6-7dc5-4e2a-b80f-3b6584ad74b9-jpg.3753224
3ff0fdc0-c1d1-4012-8087-862aa51802ae-jpg.3753225
b9944800-2abf-4aeb-b666-06c950d281ea-jpg.3753228
0ee00ba1-9830-4a54-8764-08d3d782d1a0-jpg.3753229
What"s the p/n? I beleive the taper pin is different for Tacoma vs 4R/FJ.
Curious what makes Total Chaos a better choice?
There’s no stamped part number, didn’t come with a box. I bought it off a member on this forum (terminal4). The total chaos is more beefy, bigger uniball, more bling factor (since it’s not black)
the UCAs are very similar. the tubing, shape of the tubing, bushing material/brand (likely both energy), zerk fitting, caster correction at lift, etc. are all likely the same or very similar. the biggest difference i see is the way the uniballs are designed. look at both side by side and pick what you want on your rig. i wouldnt say one is better per se. i liked the uniball design on the total chaos so whats what i went with.
the only other difference i see between icon and total chaos is total chaos gives you another (more expensive option) to replace the poly bushings with adjustable heims. totally not needed for most applications, but i just thought i would throw that out there.
TL;DR: 'pick the one you like and be a dick about it' :)
PRWhite
