DenverKid24
I've read some threads but haven't seen exactly what I am looking for.
I had just had the truck in the shop to have a new head gasket put on and same with the water pump and timing belt.
I had just read on their receipt that they had cleaned the mass air flow sensor (which I had done recently) as well as the throttle body when they were in there.
So anyways I was driving and the cars check engine light came on and then the car started to make a chugging noise like it was out of gas, but it was full, so anyways I pull off ASAP. The RPM's started to fluctuate like crazy and then it lead to it stalling. It happened 3 times before it stopped and I was able to drive it home. The check engine light is off now unfortunately so I can't pull any codes, but am taking it to Toyota to have Toyota check it for recent codes.
But with the throttle body and MAF just being cleaned, could that have made the computer glitch for a second (that is what Toyota thinks might have happened when I called them)? Or what do you think could have caused it?
Also, its a 1999 SR5 4runner 3.4L V6 automatic and I can't seem to find the idle adjuster either.
Any help is greatly appreciated as I am stumped.
