If my stereo has sub-out and is 200wat do I need an amp?
grantman54
I have a Blaupunkt mp41 sanjose stereo. On the face plate it says sub out 200 wats. I go to thinking that this would mean I wouldnt need an amp if I was only running a 100 wat sub or so.
is this true or is this totally irrelevant
That is just a pre-out specifically for a subwoofer amplifier. Most decks have 3 pairs of pre-outs (front/rear/subwoofer).
Never believe the wattage rating for a head unit. Sure it says that its rated to 200 watts, but in all reality it doesn't put out anywhere near that much. They rate those in a way that the peak output for a split second was able to get to 200 watts, no way its a 200 watt constant output. If you think about the size of a 200 watt amp (50x4), and then think about your headunit, do you really think you can fit the power of that amp, plus all the other headunit items into that space? The answer is no. So, to answer your question yes you need an external amplifier.
Also, just so you know that is telling you that your headunit is a 4 channel headunit and for each channel it can produce up to 50 watts. So even if you hooked up a sub up to it, you can't combine the channels together to power your sub, so the most it would allot is 50 watts max.
If your headunit has preouts (3 sets of RCA cable connections Front, Rear, and Sub) then you want to run that to your amp and then to the subwoofer.
Never go off the ratings posted on a headunit by the manufacturer. They will usually have enough to power to push some lower end midrange speakers, but thats about all they will do.
totally irrelevant
thats 200w max combined through all channels, and a full-range signal (easy way? MADE FOR SPEAKERS)
Pick up an amp that has the same or more RMS(constant power) rating as the sub, you will also need, power wire, RCA's, and subwoofer wire
Most retailers will have complete power kits, and RCA's
