If you moved from a 3rd to 4th gen, how do you feel about it now?
Quick overview:
03-04 had flat topped fenders/wheel wells, 05-09 rounded wheel wells. Front and rear bumpers changed a little too.
06-09 received projector headlights
05-09 V8's got VVTI which increased power some.
03-04 V6's got a 4 speed auto, everything else has a 5 speed auto.
Some of the earlier models had a dipstick tube on the transmission vs a 'sealed' unit like previously mentioned.
This is super helpful and convenient. I appreciate you putting the time into this.
Haha that comment about the suspension made me laugh. Sounds like you all are pretty happy with the 4th gen. It kind of surprises me that even though there are problems with the V8 headers, and the potential head gasket issues associated with the V6, that none of you have mentioned those being something that makes you nervous.
For what it is worth, there are plenty of problems such as LBJ failure, pink milkshake etc with the 3rd gen. I guess you just have to find a package that works and fix the issues as they arise!
I like my 2008, it's nice and feels luxurious. However the 3rd gens were the best automobiles made. I'd still be driving my 99 if it wasn't totaled by a drunk driver last year.
if you have a third gen and you have taken care of keep it. You can't easily go buy a well taken care of third gen.
The main thing I like about the 2008 is the all wheel drive. My 99sr5 only had 4wd.
4ths gens are nice but keep your third gen as long as possible. Maybe even park the 3rd gen and get a 4th gen as a daily driver.
This is honestly probably what I will do. I bought my '97 SR5 4WD with 173k miles for $1500 and have sorted it completely for $1200 ( new radiator, fluids, tires, LBJ, suspension + a lot more ). I look at it as I got such a good deal for it, I can just keep it and it will be my forever backup work horse when I need it. Then I can daily drive something newer/nicer/more comfortable when I can afford to do such.
Skimmed over the replies, so excuse any repetitiveness. I've never OWNED a third gen, but they're so common I've gotten plenty of time being around buddies and learned basic some mechanical work off of them. Simply put, 3rd's seem easier to maintain cost and labor wise, and being smaller offer a better option for building for offroad.
That being said, I'd never go to a 3rd gen if it meant letting go of my 4th gen. The added size, better looks (IMO), and simply "updated-ness" of them is why I got a 4th in the first place as opposed to a 3rd.
Key things if you'll buy one, I wish I knew beforehand:
-V8 all the way (huge debate on here so it's definitely personal preference), but I never tow and am still thankful I have the extra power for when necessary. The intake manifold leak is an issue, but it's a straight up fix (just costly), so there's no guessing on how/what to fix. Also the most overlooked feature of the V8: IT'S FULL TIME 4WD
- 06+ -> Mostly bc of the small updates that Inv4DrZm mentioned, less of a headache for future problems. Also the "Newer" one you find, less chances of rust built up on the frame and other components
- SR5/Sport/Limited really doesn't matter from what I've seen bc most of the differences can be modded to get whatever you don't have. (ie leather seats, adding a sport hood/spoiler/roofbars, touchscreen HU,). I do enjoy that my limited has heated seats though. Maybe look to avoid XREAS if you plan on doing a suspension lift, and avoid the JBL synthesis system if you plan on upgrading the audio. As these two features just make the upgrades more expensive, but still doable.
- Make sure you 4WD actuator goes into 4LO as this is a common problem when it hasn't been used and is a costly fix.
I second the idea someone else mentioned, why not keep the 3rd you got (seems like it was a great deal) and grab a 4th gen for more daily stuff and enjoy the on road advantages over the 3rd gen.
Last bit of $0.02, I think the 4th gens are really easy to update to keep it looking more modern. Between headlight upgrades, to 5th gen steering wheels, blacking out the interior, push-to-start kits,etc.. a 4th gen can still look like a vehicle made in 2015.
Quick overview:
Just a minor correction on what Inv4drZm posted, the 03, 04, and 05 had the flat top wheel wells.
The 03 V8 had the 5 speed transmission with a dipstick, 04 through 09 V8 had the "sealed" 5 speed transmission and no dipstick, to refill the sealed transmission there's a fill plug on the right/passenger's side of the transmisson, and there's 2 plugs on the pan, a drain plug and a fluid level check plug, to check the fluid level the transmission has the be at a certain temeprature, if I recall around 115 to 120 degrees then you pull the fluid level plug and if no fluid comes out it's low, if more than a dribble comes out it's over filled and you let the fluid drain out until it become a dribble and the level is then correct, all of this procedure has to be done a a perfectly level surface.
The 03 and 04 V6 had the 4 speed transmisson and a dipstick, 05 through 09 V6 had the sealed 5 speed transmission with no dip stick same as the V8.
06 through 09 as mentioned had the projector head lights and also a little bit different shape on the bottom, hood in the grille area is also a bit different shape as well as the grille.
I had a 99, an 04 (V8) and now an 07 (V6)
IMHO if you're going to do hardcore trails the 99 wins, but I LOVE my 07 V6.
I wouldnt mind having another 3rd gen but it would have to be VERY clean lol
Great replies! I know you are all very familiar with the 4th gen and have more knowledge than I do. I'm glad to hear you are all enjoying it. I welcome any other comments.
Yeah this is interesting! So what is your opinion on the V6 vs V8 since you have had both of them? What made you want to get a V6 rather than another V8?
Thanks!:cowboy:
Thanks!:cowboy:
V8 is full time 4WD, so you have better make sure, you a full size spare, and if you get bigger tires better get 5 as as you cant drive in 4wd with one tire that not the same size, to much stress on the diff.. The V8 oil filter is on the bottom of the engine, just a little more work to get to it.
The V6 is selectable 4wd, the oil filter is on the top of the motor, mush easier oil changes.
As far as horsepower I honestly did not notice any power difference in either.
I know lots of people want the V8 and some even seem to to get their feelings hurt when I say I like the V6 better lol but everyone is different.
For what I do, how I drive it, where I wheel it just makes sense to me.
In the end, its your money, your ride get what YOU want.
:party:
I'm going to get flamed for this but nothing sounds as good as a healthy V8 exhaust :rockon: You can put all the fancy exhaust on a V6 but it ain't gonna give you a woody like a V8 exhaust does.
Running away now!!
I use to own a 00 4runner for roughly 3 years, sold it and purchased a 06 Sr5 about 4 months ago.
So far I am very happy with the switch, I orginally purchased the 00 4runner as a camping vehicle to stick close around home. Last winter I built a teardrop camper and took the 00 on a few long road trips. That is when I decided it was time to sell the 00 and get something newer with a little more power.
So far I am happy with my choice, more room inside the cabin, quieter going down the road, larger fuel tank, better mpg. I do miss my 00 but it was not my daily driver (and it had major rust issues).
The 00
The 06
:party:
Definitely great points were brought up here. I didn't think about the 5 tire purchase piece of the puzzle. I also find it interesting that you didn't notice any power difference.. That is a first but I am glad that you are enjoying your new rig!
alia176 - haha I'm sure some people are thinking: :hunter:
ryananderson05 - Both of those rigs are beautiful, I'm glad to hear you are happy with the upgrade! Towing is a definite plus for the 4th gens. I'm guessing that is a V6 model because there is no V6 badge?
Yes I have a V6 and it feels like I have way more power than my 00.
Another thing to note is I am in ND where we don't have any challenging trails.. MN has some forest trails so I opted for comfort on road trips rather than keep the 2000.
Here's my 2 cents. I've owned two 3rd gens and one 4th gen. My first was a 99 with the 3.4 auto. My second and currently still in the fleet is a 99 with a 2.7 manual. I had pretty big plans to keep it as a pavement queen including adding a turbo but I started to see some limitations in the past few years. I even had 01 sport interior parts to swap into the car but never got around to doing it. Here are my pros / cons with 3rd gen ownership (may be a reiteration of what some others have said on the thread).
Pros:
- felt more connected and mechanical in driving
- simpler maintenance (IE brake master cylinder doesn't include replacing the entire ABS unit)
- less electronic nannies (TCS / VCS)
- the handling on mine felt more like a rwd car (maybe partly because its lighter and was only 2wd) - similar to comparing my FD to my former RS4
- dual auto front window down function
- availability of 5 speed manual
- aftermarket parts availability
Cons:
- some what dated controls / interior ergonomics
- lack of power (felt this more in my 3.4 than the 2.7 mainly because of the manual, but I still felt the limitations of the 4 cylinder for sure) availability of boosting options helps here though
- uncomfortable seats for long trips
- not much else to dislike - just the usual older car stuff
I was up and down between getting a 5th and 4th gen around this time in 2017. I got some good time driving my friends 5th gen limited with full time 4wd. I test drove one beat up 06 V8 4wd from a local used car lot and decided that I needed to find a 4th gen V8 for sure. Between the two generations, I felt they handled pretty much the same. The 5th gen My decision to even contemplate buying a non-3rd gen was shocking to me but mainly I wanted something a bit larger to transport my dogs around. If were just me, I would have continued rolling along with the 3rd gen. I've always been a die hard 3rd gen fan, thats why I bought a second one to finish the project I never finished.
Anyway, I bought my 4th gen sight unseen and flew into Philly 6 weeks after buying to pick her up. I pretty much changed my mind instantly after I drove her off the lot. At 143k miles, she felt like she had only done like 30k. Even the tired XREAS made the truck feel pretty plush for the entire 1000 mile road trip back home. Here are some pros / cons to the 4th gen from me.
Pros:
- V8 availability (I'm not going into a debate but I did mainly pick the 4th gen for this reason)
- interior is very similar to the early 5th gen (2010-2013) - so it feels not as old especially with an updated carplay / android auto unit
- seat comfort on long trips (I used to get back aches in the 3rd gen, I don't get them in the 4th gen)
- rear seats fold without needing to remove the head rest (its the little things)
- extra storage compartments in rear wheel well
- electronic closing rear hatch (not auto close but you don't have to slam it to close the rear hatch)
- XREAS is comfortable (although I ditched this already and it still feels pretty decent with the aftermarket setup)
Cons:
- size (it feels much bigger than my 3rd gen and makes my 3rd gen feel like a sports car) - although it also has a larger cabin
- handling (handles like an AWD vehicle with more understeer feel vs my 3rd gen / also feels less connected to the road)
- V8 timing belt (2.7 on 3rd gen and the 1GR has timing chains so this is a V8 specific item) - I don't see it as a con because most cars have this as a maintenance item
- front calipers prone to freezing (my passenger front was frozen) - I fixed this by going with an aftermarket BBK though (not a route everyone is willing to go with but with the amount of money being thrown around for suspension and engine upgrades, I figured its worth the investment and time. Time is golden for me, service it once vs having to replace frozen calipers every few years)
- complexity for maintenance (more sensors / solenoids that can go bad over time) - IE: secondary air injection pump issue (v8 specific), 4wd lo solenoid
- add on of VCS, TCS systems (just modernization I guess) - at least you can turn them off without some silly pedal dance process like the FT86/BRZ
After I came home with my 4th gen, I still drove my 3rd gen on and off for 2 months after I got the 4th gen but after I got it registered, the 3rd gen has pretty much sat in place since late March of this year. I only drive it once every few weeks to keep the parts moving. I'd keep it as a fun car, but 5 vehicles for one person is just too much. I love my V8 4th gen and have almost jumped at the opportunity to pick up a lower mileage one several times, but for now I'll save my monies and continue to enjoy the one I have. I know if anything happened I'll get another one for sure. It fulfills all the check boxes the 3rd gen does and more. Those are my 2 cents as far as daily drivability.
Pros:
Cons:
Pros:
Cons:
Great reply! I really appreciate the time you put into this comprehensive response.
Hey man, I'm pretty sure you are the one who sold me the factory 5 star 3rd gen wheels, am I right? I recognize that FD and I see in your signature you also have a FK8. I'm sure that is no coincidence haha. By the way the rims are working out great! :guitar3:
I decided to keep my 3rd gen after buying a 4th gen. I've been driving one for about a month, then switching over to the other for a month.
When I get back into the 3rd gen, I always say to myself 'gee I love driving this thing!'. Then when I get back into the 4th gen I say to myself 'gee this thing is so much nicer'. And the cycle repeats....
Haha glad they worked out for you man. Did you end up refinishing them?
I haven't. I have refinished several sets of wheels, and at this point they would be finished via a DIY method. Spray paint and plasti dip in my opinion are too soft and the factory paint is still decent enough, especially at 10 feet away haha. Glad to hear you are enjoying the 4th Gen.
One thing that nobody has brought up that seems like a big deal is the V6 head gasket issue on the '04, '05, '06 rigs (predominately). Is this something that concerns any of you? Does anyone feel like the V6 head gasket issues are a reason to buy a V8 model even with the potential cracked header issues related to the V8? Of course any vehicle is going to have their own idiosyncrasies.
Sent from my A0001 using Tapatalk
My v8 has cracked headers. I just haven't gotten around to ordering replacements yet. Doesn't affect my enjoyment of my rig though.
