Ignition help !?!?!
1stgenfan
I've done the searching on site and google. no help there
So i have a no start. ECU is fried. im getting good compression but no feul and no spark. i know because its EFI the no feul if from the ECU being burnt because it was working fine before.
now my question to you. the no spark. would a bad ECU cause a no spark or am i looking at a new ignition control module aswell ???
i am really hoping when the ECU comes i'll plug it in and it'll fire right up. but im also starting to think these are high hopes. if somebody can confirm if i will need the module or not i would be greatly thankful
I dont want to spend the $300 for a new one. but if i have to i might aswell do it now while im waiting for the ECU so she's ready to go when it gets here
aswell does anyone know of a good bench test for the module. the ignition coil is fine as ive confirmed thru bench testing its just the module im needing help with
the ecu controls everything if its fried you wont get fuel signal spark signal cam signal nothing replace the ECU.
Replace the ECU its your only hope.
you wouldn't expect a commuter to start without a mother board would you?
