Ignitor testing?
dinger
Since getting my 4runner back on the road it developed a problem. It will start missing between 2-4k rpm. Ran diagnostic check got code 12. Engine speed (rpm) sensor circuit-distributor, ignitor, starter or ECU. I tested signal generator and coil, both good. I checked air gap its good. I have looked for how to test the ignitor. All I can find is saying to test a known good one. Or just replace it. I don't have one close by to check and don't want to spend the money on one unless I know mine is bad. Just because everything I've read similar to this thread ends up talking about the TPS. It's good and adjusted properly.
Does anyone know what the ohm readings should be?
Please help me out. I'm tired of road rash driving a eclipse tuner car
You can get a spark tester from Harbor Freight and borrow your kid's Gopro.
You can film it at your various rpm levels and see if you have gaps in your spark. In my case on a different brand, my Crank Position Sensor was all gooed up and dying.
Philthyphilthy
