I'm angry
2gen4runner
So just recently i replaced my starter because it was not working properly......I put the new one in and it worked good for the first week, then it started acting up to where i would need to hit it.....BRAND NEW $80 STARTER :flipoff: yes im very angry...Why is this happening? Could it be a bad starter or what???? Plz help me before i drive my 4runner off a cliff!
Toyota/Chrysler/Mitsubishi - Nippon Denso Starter Solenoid Repair
Roger Brown is your friend. Roger Brown knows what is bothering you, and Roger Brown has the answer. Roger Brown is my hero.
Starter relay.
2nd generations are well known for having a bad starter relay. Find it. Replace it and see if that helps.
i would vote a grounding issue sense all the starter grounds to is your engine and tranny you could try taking the engine ground off cleaning it with a stainless steel wire brush then reconnect it. if not the full issue its a good thing to do every 5 years.
