I'm getting around 9mpg in the city.
Schwooby
I have a 93 sr5 v6 with an automatic transmission. No lifts, stock gears.
Reasons why my gas mileage is so horrendous?
The only thing I've swapped is my thermostat. That was a couple months ago. The temp gauge is at about half once its warmed up.
You might start with all the usual stuff like a tune-up, check the timing, check compression, tire pressure, switch to manual hubs, alignment, etc.
If/when you do a complete tune-up make sure you use only OEM parts. Our classic 4Runners do not like anything else. I speak from experience.
Is your air filter real dirty?
Does the check engine light come on when you start it and then go away as it should?
Can you tell if the exhaust looks rich?
I would start by pulling the plugs to see what they look like. Then maybe new plugs, wires, cap and rotor... Be sure to use the correct NGK or Denso plugs.
Check the exhaust flow for a possible clogged cat.
great..... i went all aftermarket, guess itll work for now.
op good luck. i too am working on improving my fuel mileage on my 3.0
Awesome advice. Thank you!
I just went through the same issue. See my post and see if anything there might help.
"Terrible Gas Mileage" as one of the smart responders said here don't use after market parts. I tried a AF fuel regulator and it tore me up trying to figure what the static pressure on fuel line would not hold.
Hope everybody here helps you. I had some good ones!
This forum ROCKS, great people here.
Good luck broO:cheers:
Just wondering if you've found anything? I too am only getting about 10 mpg. I know I need to do a tune-up but was just checking to see if you found anything significant that I could keep my eyes open for.
H.Sikina
