I'm pretty sure I'm not supposed to have extra bolts after the job is done. Does anyo
mymalade
Yes, this seems like a silly question, But I recently completed changing out the clutch pedal bushing (took me almost 2 months to actually complete this 10 minute job). And when I was done I had a mystery bolt that literally seems like it fell out of the sky.
I pulled out the entire pedal assembly which only had one bolt under the dash, -a black 14mm bolt, But I did end up taking off the knee panel, and AC vent tube to give myself more room. The bolt in question is a gold, 12 mm headed bolt.
I literally went out one morning to finish the job, and the bolt was laying right in front of the clutch pedal. I'm 100% positive I didn't remove it, And I tried searching all around under the dash to see where it could have come from but I don't see any threaded holes. I don't believe it came from the dash panel since all of those are 10 mm bolts. Does anyone have a clue where this could have come from?
I hate to respond just to say I've got nothing...but I've got nothing. That is a totally generic looking bolt I've seen and removed 100 times while working on the interior of my 4Runner.
12mm suggests it's meant to secure more of a main component than a trim piece.
Good luck!
Sorry if this posts weird, my first time using the forum.
That kind of looks like one of the bolts that holds the panel under the steering column. I replaced mine recently and it had 4 gold bolts that looked like that one.
I could be totally wrong but it's a good place to check.
Not weird at all and thanks. Do you ,mean dash knee panel part? That's where I originally thought it came from, but all four of mine are black and are 10 mm so they are different. I still can't figure out where it came from
matisgugle
