im vibrating everywhere!
dsrtflcon7
hey, it all started when i purchased aftermarket brake pads from napa (bad idea):bash:
first they started making noise and ended up in bad steering wheel shaking.
i got my rotors cut and my rear drums adjusted and put oem pads which i should of done in the first place
that took care of my brake problem.
now as im going on the free way and reach 60mph the whole truck vibrates
and especially when i push on the gas
ive been told its my drive shaft and that it could just be worn u-joints
what parts are recommended and from where?
i have a 97 sr5 2wd any advice would help
thanks in advance!!!
i have a somewhat similar issue. I have this growl/vibration when i step on the gas. its been that way for a long time
Well if it is drive shafts, then the natural question is, Have you properly greased them recently? that may be all you need unless the u-joints are just shot. Also check the slip joint.
Check the tutorial and document reference sticky for details.
