Dirt4dinner
I got it done yesterday.
I installed a Cobra WX ST II under the after market CD deck. I was able to use two of the holes in the CD player cage to fasten the CB to the cage also. I have been told that you don't need to do this, because the CB is such a tight fight that it won't move around. But the holes were lined up...so why not stick a screw on each side? I also added the Wilson Lil' Wheel magnet antenna.
I ran the antenna cord off the back of the CB using a Elbow adapter to make sure there was enough clearance behind the CB, the cord runs along side the 4wheel drive stick, under the center console, under the carpet between the front seats and back seats, then under the carpet again under the back seat and then where the seat belt is held on next to the back seat I ran the antenna up that pillar to the head liner where it pops out. I had the antenna wire cut and mounted two males ends to the cut and use a two sided female plug so that the antenna can be removed, but the antenna wire I ran up the center of the car stays put.
So...here are some pictures!
Full picture (I took the runner boards off yesterday...looks SOOO much better!!!)
In the dash.
The plug at the headliner so the antenna is removable.
The antenna and wire leading to it.
In the dash.
