Info on these TRD wheels
Yes I pretty much want what the TRD Pro has. The main reason is I don't really want to trade mine in since the TRD has no moonroof plus I like the stock components the TRD has.
I was in your same boat, wanted moonroof and KDSS. With your same intentions I set off to build my TEP into a TRDP, however I found many on this forum seemed pretty excited about a variety of possible suspension upgrades.
Nothing wrong with the 5100's, but other options can allow easily changing ride height, others like mine have adjustable ride . . . etc.
Throw the TDRP wheels on if you like the look and check out some of the great suspension options that may better suit your needs.
My .02
How do you fit 16" wheels on a 5the gen? Downgrade the brakes?
ICON Vehicle Dynamics Entry Level Suspension System for your 2010-Current 5th Gen Toyota 4Runner works well in most on and off-road scenarios. ICON Vehicle Dynamics front coil-over shocks are tuned specifically to give your 5th Gen 4Runner a great ride quality on and off the road.
The rear shocks in the system are tuned to match the front coil-over shocks in every aspect, and the 2" lift coil-springs are slightly firmer to help with the ride quality and handling as well as to support the addition on any necessary gear or equipment. Recommended tire size 285/75R16, wheel 16x8 with 5" back spacing.
Stage 1 System Contents:
58646 - Standard Travel Adjustable Coil-over Shock Kit
52700 - 2" Lift Rear Coil-spring Kit
56505 x 2 - ICON 2.0 VS Series Rear Shocks
that spec is incorrect. cut-and-pasted from elsewhere most likely.
Damn you guys are just realizing that, he's started like 10 threads in the past week on the same s**t.
Damn, hadn't checked the forum in a while and bit right into that one...removing the taut line hook from my mouth now... On the upside tho, the responses and witty banter are pretty comical on some of those other threads.
Should I go with the black or matte gray TRD wheels on my silver SR5? Is the backspacing the same on either one?
I just put on the Cooper A/T3's, great tires! Some people actually told me to leave the SR5 wheels as is. Any opinions?
Both the Gray and Black are identical. I think either one would look great but I chose the black for more of a contrast. I can't believe how many thumbs ups I get while stopped at the light from fellow 4runner owners. All because of the TRD Wheels and Duratrac Tires. While I like the SR5 Stock Wheels, I like the TRD Pro ones better.
Have any pics of your set up??
Actually, mine is the Nautical blue. I wanted black because gray was similar in colour to the stock wheels. On a Silver 4runner the contrast of the black wheels would be greater and give a different look than the gray ones. I don't think you would go wrong with either choice.
4runner2a_zps73d410a6.jpg Photo by chum8888 | Photobucket
Black looks great up close, but from far away it almost looks like you have nothing but hubcaps. That is why I was thinking about the matte gray.
