Hello all 4runner guru's. i'm relatively new to the 4 runner sceen and picked up an 87 with the 22re motor with a 5 speed 4wheel drive. good deal. but now i'm running into a problem with the number 2 injector. the wire i guess was corroded and the number 2 injector is not fireing, is this a common problem, i pulled the tape off the harness and found some bad connections, fixed that problem, it seemed to work for a bit and now hitting the same problem. Is this normal, do i need a new harnes from the computer to the motor and if so where can i get one? the computer was thought to be the probem so it was replaced and then we fixed the wire that seem to work for a bit. thanks again
