Injector purchase
Yeah I remember reading about that. My guess is the ECU is different on those rigs and there was a electrical difference in them for that ECU.
That’s what I was thinking. Because I have a set of USDM OEM used injectors that are in spec. Except they are the Browns ones. And my 97 has the gray/greenish ones.
I’d like to keep them for back up. Just as long as those would work correctly with 97 ecu. Even though they are USDM.
i have a 99 limited. I bought six(6)new ones off ebay for 65 bucks total. I have a bunch of miles on my 99 also. I put 3 of the new ones in (1,3 and 5). They worked great. Got the other 3 to do sometime down the road. You do want you want, but i skipped the oem route.
Gonna do my knock sensors soon and was thinking about replacing my original injectors with a "rebuilt", cleaned and tested ebay denso oem set. My originals seem to be fine, but since I will be tearing everything apart I thought this would be a wise idea. Any thoughts on this?:)
I recommend not replacing them but having them cleaned and flow matched by either witchunter or Dr. Injector.
I met "Dr. Injector" of Sacramento and he did a fantastic job on my old injectors from another Toyota with 300k miles. Very professional and did a great job. He also told me that if I ever found 4-hole injectors for that vehicle they have a better flow pattern and would burn better. He was right. I installed the 3VZ-E Flamethrower injectors and the truck ran better and got better gas mileage. He really knew his stuff.
http://www.doctorinjector.net/
I wanted to follow-up and post more info on the rebuilt injectors I got from LCE Performance (https://www.lceperformance.com/5VZ-V6-Equalized-Fuel-Injector-Set-99-04-p/1062211.htm) OP, idk if you care but I figure someone might stumble on this thread in a few years and appreciate the info.
They look identical to the OEM injectors except for the color of the pintle. I replaced the one injector that was causing Cylinder 3 misfire and the problem is solved so I'm happy about that. I'll installed the other 5 injectors when I do my knock sensors in the next week or two.
I paid $300 for the set of 6 and I'm thinking I could probably have found a better deal for the same parts, but whatever I'm just glad I have some new injectors and didn't have to pay dealership prices.
Click pics to enlarge
old vs new
old vs new
old vs new
old - looking through one of the two holes at the tip and you can see the four-hole spray pattern
new - same four hole spray pattern
lillwill,
I just went the eBay route with a full rebuilt set, $51, shipped from CSP or CSP performance (not in front of me). #2 was misfiring and I had 365k miles on the ORIGINAL set. Put the rebuilt set last week-- good to go. The remans from this seller were OEM remans.
Performance has been good for ca. 400 miles thus far, no more hesitation, mileage has recovered, too.
YMMV. Good luck.
