Installing double din and backup camera
alms_lefko
Was going to buy the Pioneer AVHX4600BT.
Add the:
PAC TATO & PAC SWI to retain factory JBL amp and steering wheel controls
My question is whats a good backup camera? I saw ones where I remove a licence plate light and add the camera - but then that seems like the camera is off center. Don't I want the camera as centered as possible?
I'll just say that no matter how good your backup camera is and how well positioned it is, you should NOT be staring at your camera while backing up.
Use the camera like an additional mirror that provides another vantage point, and with that attitude it wont' really matter if it is off centered.
I have purchased multiple cameras off of amazon (although none for a 4Runner) and my favorite is Amazon.com : Pyle PLCM37FRV Universal Mount Optional Front View & Rear View Backup Color CMD Camera with Built-In Distance Scale Line : Vehicle Backup Cameras : Car Electronics
Depending on how you wire it, it can have or not have backup lines and you can reverse the image if desired.
I stare at my cameras when i back up and i have 3 of them in my truck.
Front, Rear and Side turn signal cam.
I personally would not recommend anything from Pyle. In the industry we call it a "pile of shit".
spend the money on a camera that is recommended by someone that installs a ton of, like me. or buy name brand from kenwood or pioneer and you will not be disappointed.
side cam
rear
front
Add the:
Im thinking of replacing the oem nav unit also . seem like the only difference between AVH-X4600BT vs AVH-X5600BHS is the xm and hd radio.
How difficult is the install. Is it just plug and play? I would like to keep the steering wheel controls also..
Im not a audiophile. However is the spec. it says navigation optional?? how does that work?
Ok sorry, I should have only spoken for myself.
I have front, side and rear view cameras on my Land Cruiser. I only use my cameras to gauge distance from objects, I still use my side view mirrors and my back window (when I can see out of it) to do guide my actual movement.
I only spoke up because I've encountered people who feel that a rear view camera will solve all their parking difficulties when in reality it just gives you another viewing angle. Just like I can't back into a parking space only looking at my rear view mirror (I need to use my side mirrors and back window if possible), I can't back into a parking space only looking at my rear view camera.
edit: well I probably could, but don't feel safe or confident doing it.
This ^. I just recently installed a backup camera (the one that replaces the factory light) and it's a great asset while reversing, but I don't fully rely on it. I mainly use it for checking how close I am to the garage door and making sure I don't run something over.
My camera view is actually pretty center. Obviously not perfect but it's not off enough to make a difference.
then again i also stare other things too...sometimes i get caught doing it (.)(.)
LOL
i stare at the cameras but like you said, i use it as a tool to help my parking, its no replacement for common sense!
what are some cost effective recommendations from a guy that installs a ton of them...
i will installing a scion touchscreen specifically for a backup camera, so i would like to hear some options, thanks!
i can send you my cluster, steering wheel controls and a camera. you send back the cluster and steering wheel control with new leds in there :)
that might work! i would want to know what camera it was before i committed.
I have a whole case of these that I import from Korea private label. I buy cases(50 pieces) at a time. If you can read korean that's what it says on the box lol
honestly....I spent $10 on a camera from amazon and it lasted me 3 years before I had to replace it. you get what you pay for but $10 for 3yrs isn't bad. i just replaced it again with another cheapo one and it works great.
i didn't want to drill any holes or spend a lot of time wiring so i took one of the bumper screws out next to the trailer hitch, put the screw through the mounting bracket, and screwed it back in. easy quick install and it gets a good view
like others said don't rely on it, i still look out of my windows and use my mirrors more than my camera.
this concept is fine when you DIY, but when i sell and install 15 pieces on a slow month. a few coming back for warranty and repairs can really cut into the bottom line. So far out of ~300 pieces, i had 8 bad 4 are sold over the counter, coincidence?. 3 were installer error and one DOA. So i would say i had only one bad out of the box in the last 2 years
[MENTION=93434]gshadow325[/MENTION] of course, if I was installing on customer cars I wouldn't go this route. but for someone who doesn't rely on it or use it much the cheap route made more sense. I've been doing car installs for 20+ years so the install is correct and clean, its just a cheap camera that's exposed to the Colorado elements year round. spending $10 on a camera every few years that takes me 5mins to swap out isn't a big deal to me.
Which one replaces a factory light?
What are you using for the display?
This;
http://www.amazon.com/gp/product/B00GUAH2I2/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
It works great for a cheap Chinese product. Only been using it for a few weeks though. But I bought 2 of them just in case, because they're so cheap. If it craps out it'll take half an hour max to replace it.
I have a Kenwood DNX5120 HU. But it's a simple RCA cable so anything would really work.
This;
This thing still holding up ok? I was looking around on Amazon and this looked promising.
How does the LED that replace the stock light look? Did you have to replace the other side to "match"?
Any pics? :peep:
installed the license plate type from pyle. just screw on license plate and hook up the cables..worked for 2yrs and crapped out, cost a lil over $20, bought another unit to replace the failed unit...
didnt want to spend $150 on the panasonic rear cam
I recently installed a 5600bhs. I also installed a camera.
Just FYI.. I used metra harness converter to keep the oem AMP.
One thing I dont like about it is it has a low frequency air/noise even if the stereo is off.. Its very slight but still annoying.
I also used metra axxes steering control. it works flawlessly.
For the camera. I used a cheap amazon one. for 18 bucks; if it breaks il just buy a new one. Note the video wires are not long enough so you will need a rca connector/extension.
I just mounted the camera with 3m double sided tape under the right side of the license plate light. It does not look too much off center.
Final note... Spend an extra 15 dollars to buy a bypass module..
The new stereos will not bypass the E-brake. I tried grounding the wire and even made a relay switch.. In the end I just bought the bypass and all you have to do is connect 3 wires. Its small and cleaner.
Of course the easy way is to pay 300 dollars for a shop to install.
Any pics? :peep:
Still working like a charm!!
I really like the LED in the camera but it no where near matches the stock light, haha. The LED is a little blueish and obviously brighter. You may be able to match the LED color but not sure how to install it.
Honestly, my right side license place bulb has been burnt out since I put the camera in so I've only been running the LED light :lol:
I'll try and get you some pics tonight.
