installing engine
kimsey
To begin with, I did not remove the engine so I don't have anything to reference to where two things need to go.
Facts:
1995 3.0 V6 5spd 4wd
The first is an electrical connection. Its on the drivers side and is on the same run as the electrical plugs for the fuel injectors. In fact, it splits off at the same location as the middle injector. I have searched, but come up empty as to what it should be plugging into. Any help?
The second problem I have is the lines off of the power steering pump. I can not find where these are supposed to hook up to. Any suggestions?
Thanks- Chad
Figured out the power steering lines...
they were actually vacuum lines.
Still trying to figure the electrical connector out though.
