Installing new lights?
yotaman04
I recently purchased some clear corner/bumper lights, Xenon HID headlight bulbs and Altezza smoke taillights. I was wondering if I could install them myself or if I should have them professionally installed. If it is easy to do yourself, what all is needed?
You should be able to do all of them yourslf. The only thing that may be a ***** are the Headlights. So you may have to get someone to do those, but you can save yourself some money by doing everything else.
If the HID's are only bulbs it very easy to replace them. I changed my bumper/clears, headlights, and chrome altezzas myself. Very simple to do. If you go to your local autoparts store and pick up a maintence book, it tells you how to do everything. Greatest investment I ever made in the Runner.
HID's are very easy to install, if it's plug and play it should only take you about 30 minutes. The only hard part is mounting the ballast. Post some pics when you get everything installed!
The installation of the headlamps and signal lights is quite easy, you should have no problem.
Sorry to say I don't have any experience with the HID's to pass on.
Good luck!
Does he just have bulbs or a kit? If it's bulbs it should just take 10 minutes.
With the corners you just unscrew the one screw you see with the hood up and pull very hard directly toward the front of the truck and they will pop loose.
Signals are just held in behind the bumper and are easy out and easy in.
