Installing OEM turn signal side mirrors to a TRD Pro?
AP19Delta
Have anyone attempt to install the 5th Gen Limited side mirrors to the TRD Pro?
If so can you provide a block instruction please?
This type mod has been discussed, and IIRC not feasible, primarily because Toyota does not build in the wiring to do this. Plus, the parts costs would be outrageous.
Someone will say "anything is possible for enough money", which is why I said "feasible".
What does it being a pro have anything to do with the mounting of the mirrors? They will bolt right up to any 5th gen 4R. only question is if the harness is already wired up.As far as Replacing it goes like this remove interior trim covering mirror bolts, unbolt mirror, install new mirror, attach harness or splice new, re install trim...Done
This type mod has been discussed, and IIRC not feasible, primarily because Toyota does not build in the wiring to do this. .
Well here is the answer
Roger that. I guess I was I asking if anyone have the wiring diagram for this.
No you did ask for a block diagram so you did ask for a wiring diagram, Everthing (only adding puddles really) except for the turn signals could be spliced into the factory door harness easily.
Essentially, couldn't you just tap the turn signals and run a pair for wires from the turn signals to the mirror connector on the door.
Hmmm really I don't know if the heating strip is hiding behind the mirror or not because I don't see it on the outside of the mirror.
It is standard equip on all.
Ah OK. Good to know now. I didnt know that. Because on my spec sheet it only show outside mirrors.
It also does not say they are power! From toyotas site standard for PRO "Color-keyed front and rear bumpers with black accents, door handles, heated and power outside mirrors, overfenders, side rocker panels, hood scoop and rear spoiler; and silver-painted roof rails with black endcaps"
Jhunt
