What does it being a pro have anything to do with the mounting of the mirrors? They will bolt right up to any 5th gen 4R. only question is if the harness is already wired up.As far as Replacing it goes like this remove interior trim covering mirror bolts, unbolt mirror, install new mirror, attach harness or splice new, re install trim...DoneHave anyone attempt to install the 5th Gen Limited side mirrors to the TRD Pro?
If so can you provide a block instruction please?
Well here is the answerThis type mod has been discussed, and IIRC not feasible, primarily because Toyota does not build in the wiring to do this. .
Roger that. I guess I was I asking if anyone have the wiring diagram for this.What does it being a pro have anything to do with the mounting of the mirrors? They will bolt right up to any 5th gen 4R. only question is if the harness is already wired up.As far as Replacing it goes like this remove interior trim covering mirror bolts, unbolt mirror, install new mirror, attach harness or splice new, re install trim...Done
No you did ask for a block diagram so you did ask for a wiring diagram, Everthing (only adding puddles really) except for the turn signals could be spliced into the factory door harness easily.Roger that. I guess I was I asking if anyone have the wiring diagram for this.
Yes. But I would like the mirrors heater to work also.Essentially, couldn't you just tap the turn signals and run a pair for wires from the turn signals to the mirror connector on the door.
why is this a problem even a base SR5 has heated mirrors so they all do.Yes. But I would like the mirrors heater to work also.
It is standard equip on all.Hmmm really I don't know if the heating strip is hiding behind the mirror or not because I don't see it on the outside of the mirror.
Ah OK. Good to know now. I didnt know that. Because on my spec sheet it only show outside mirrors.It is standard equip on all.
It also does not say they are power! From toyotas site standard for PRO "Color-keyed front and rear bumpers with black accents, door handles, heated and power outside mirrors, overfenders, side rocker panels, hood scoop and rear spoiler; and silver-painted roof rails with black endcaps"Ah OK. Good to know now. I didnt know that. Because on my spec sheet it only show outside mirrors.
Yup! anything is possible. :yo:
Sunroof and heated / lighted mirrors. :rockon:
