O openexcess New member Feb 18, 2012 #1 will a 95 engine and transmission fit in a 1990? they are both V6
Rockdawg84 Active member Feb 18, 2012 #2 openexcess said: will a 95 engine and transmission fit in a 1990? they are both V6 Click to expand... should fit frame is the same and I'm pretty sure all the mounts are the same but get a tape out and check to make sure.
O openexcess New member Feb 18, 2012 #3 Its the same motor, im just not sure about the harness, and electronics
Rockdawg84 Active member Feb 19, 2012 #4 openexcess said: Its the same motor, im just not sure about the harness, and electronics Click to expand... the electronics will all swap over from your old engine if they are different. The Blocks are the same your good to go.
