Thai
Elite Member
About Bounce...
Eliminates static cling from pantyhose.
Rub a damp, used sheet of Bounce over the hose.
Prevents musty suitcases. Place an individual
sheet of Bounce inside empty luggage before storing.
Freshens the air in your car. Place
a sheet of Bounce under the front seat.
Cleans baked-on food from a cooking pan. Put a sheet
in the pan, fill with water, let sit overnight, and sponge
clean. The anti-static agents apparently weaken the bond
between the food and the pan while the fabric softening
agents soften the baked-on food.
Eliminates odors in wastebaskets. Place a
sheet of Bounce at the bottom of the wastebasket.
Collects cat hair. Rubbing the area with a sheet of
Bounce will magnetically attract all the loose hairs.
Eliminates static electricity from Venetian blinds. Wipe
the blinds with a sheet of Bounce to prevent dust from resetting.
Deodorizes shoes or sneakers. Place a sheet of Bounce in your
shoes or sneakers overnight so they'll smell great in the morning.
And now, Coke:
To clean a toilet: Pour a can of Coke into the toilet. Let the
"real thing" sit for one hour, then flush clean. The citric acid
in Coke removes stains from vitreous china.
To remove rust spots from chrome car bumpers: Rub the bumper with
a crumpled-up piece of Reynolds Wrap aluminum foil dipped in Coke.
To clean corrosion from car battery terminals: Pour a can
of Coke over the terminals to bubble away the corrosion.
To loosen a rusted bolt: Applying a cloth soaked in Coke
to the rusted bolt for several minutes.
To bake a moist ham: Empty a can of Coke into the baking pan;
wrap the ham in aluminum foil, and bake. Thirty minutes before
the ham is finished, remove the foil, allowing the drippings to
mix with the Coke for a sumptuous brown gravy.
To remove grease from clothes: Empty a can of Coke into a load of
greasy clothes, add detergent, and run through a regular cycle.
The Coke will help loosen grease stains.
It will also clean road haze from your windshield.
And We Drink This Stuff?!?!
Very interesting ........
And now, Coke:
