Interior color non options
elemint
Am I reading the Toyota website correctly (awful website btw) in that one can only not get black by getting the white exterior? What is with that???
go here:
Toyota PDF Brochure
then look at the attachment.
not happy with the factory color combos?
get some katzkins, wet okoles, or other aftermarket seat cover/upholstery supplier.
That's weird. The color option on the build program at Toyota. Com only let's you get another color aside from black graphite is with a white exterior.
i wouldn't trust it if its not in the brochure. the brochure has ALL the trim levels lined out at the end of it with a table denoting EVERY possible trim level and optional combination.
Play with it, familiarize yourself, select the trim you want with the optional goodies, and go get the 4runner of your dreams already.
You've been on here long enough to know that different Toyota sales regions offer different options. Try a CO zip code, or a VA zip code.
Also, are you just using SR5 for example? Try a different model.
Assuming the op's location is correct. I am also in Illinois and just went on toyotas website and am able to select black interior for several different exterior colors for all the different trims.
That's the problem. I hate black interiors.
QUOTE=enjanir;2308011]Assuming the op's location is correct. I am also in Illinois and just went on toyotas website and am able to select black interior for several different exterior colors for all the different trims.[/QUOTE]
Mike Sargent
