Intermittent Failure to Start
danthemanx07
I recently began experiencing an intermittent starting issue. When I turn the key I get one solitary "click" followed by a second single "click" a few seconds later. Usually, I can try to start a few times, and it will fire up on the third or fourth try. I got stuck at a shopping center yesterday for some time though, so my urgency to figure this out has increased.
Things of note:
- have tried two different AGM group 31 batteries - both under a year old with no change
- battery terminals have been cleaned and check multiple times now
- the body ground - the one that goes to the driver fender - has been replaced with a heavier gauge cable
- all the lights on the dash come on, radio works, etc.
- I have the slyfox75 secondary air injection pump bypass installed
- issue started after a fairly deep (~36") water crossing a month or so go now
- warn winch installed and wired directly to the battery - no other accessories
- voltage reading at idle is 13.6-13.9
2005 GX470 with the 4.7l, 211K miles
Any thoughts?
Assuming all connections are good like stated, this is usually a sign the starter is going out. The click is the solenoid engaging but the main starter not turning. A old trick is to hit the starter with something to get the contacts to work a few last times, but that's not really possible on the v8 unfortunately
The internal contacts get beat/worn down with age, one more than the other (not sure why). At a certain point the solenoid can't pull the plunger against them both with enough contact to turn the starter motor (takes a lot more juice than you'd think). Worn contacts plus some water creates a bit of corrosion, making the issue worse.
I just had this happen on mine about a year ago. Getting the starter loose is pretty straightforward (long extension, bit of muscle, etc) but mine's the V6. On that V8 it's perched on top under the manifold. What a pain.
Once you have it out you can easily replace the contacts or in my case they looked OK so I just cleaned them up with some sandpaper and moved on. They sell a complete rebuild kit on Amazon and elsewhere for about $35 (new contacts and plunger). In hindsight, I really wish I'd replaced them. They're cheap and would be insurance against this issue for probably another 100K.
Good luck....
I would have to do that on my old Samurai to get it to crank. Unfortunately, as you have said, the starter here is totally inaccessible.
Good luck....
Thanks for the info. The starter on the V8 is a royal pain to get at. Against my normal practices, I am probably going to pay someone to tackle this job, and if it is done, I will just go ahead and replace the whole starter and rebuild the old one as you have described.
If you can turn a wrench then the starter is not all that bad, just more time consuming. I had it done in a few hours on a friends 4runner. That said, paying someone is always easier Haha
If you hear the clicking and you know you have good amps and volts w your battery I would also look at your crankshaft position sensor. Way easier to start small. Good luck.
Southshore
