Inverted "Vee" bar on front bumpers
BettysNephew
I have seen several aftermarket steel bumpers in threads with the inverted Vee shaped bar in front of the grill at about a 45° angle. What is the purpose/use of this bar other than making it difficult to park without destroying someone else's hood?
Its called a stinger, and was originally meant for protecting the radiator in a rollover while providing a little bit ramp up with your skid plate to help to get up over obstacles. Now it has become a piece of swag for mall crawlers but a lot of real wheelers still use them.
The stinger bumper is used in conjunction with a winch. When the load starts pulling your truck instead of you and your winch pulling the load you can butt the stinger against a tree at an angle and feed the winch cable sideways with much better leverage. It's a very useful tool.
The stinger bumper is used in conjunction with a winch. When the load starts pulling your truck instead of you and your winch pulling the load you can butt the stinger against a tree at an angle and feed the winch cable sideways with much better leverage. It's a very useful tool. It also destroys deer, DHS check-point barriers and rioting Obama and Hillary supporters at inaugurations....in a perfect world.
Careful thread will get locked
The stinger bumper is used in conjunction with a winch. When the load starts pulling your truck instead of you and your winch pulling the load you can butt the stinger against a tree at an angle and feed the winch cable sideways with much better leverage....
What? Can you explain that again please?
Sure, let's say you are pulling a vehicle stuck hard in a ditch out with your winch mounted stinger and your truck starts to slide...you can pull up next to a tree and put one edge of the stinger directly on the trunk at a 90 degree angle to whatever it is you are pulling. This keeps your vehicle from creeping towards it and gives you more leverage.
So it's OK to talk about destroying crowds of people with 4runners??
There is a lot I would like to say back to this person, most of which would probably get me banned, so I'll say this.
Mods, I'm waiting.
I think I get what you're saying. Use the bumper to butt up against a tree to 'anchor' the winching vehicle. I don't see any leverage advantage though.
Personally in those situations I would rather strap the vehicle to a tree at the tow hitch and maintain a straight pull for the winch. You loose lots of efficiency when the winch line is spooling in at an angle and moving over the side rollers or edge of a hawse.
