Ironman 4x4 Lift
r3apingcha0s
So I’m looking to upgrade from my stock suspension and I am Looking to see if anybody has used the iron man 4x4 lift and what they thought about them. They have a 3 year warranty on it. But I haven’t really heard anybody with them. If so how do they compare to any other brand you have ran. Also if you recommend another brand instead that be cool aswell.
Thanks in advance.
Ironman lifts aren’t as popular with the 5th gen. A lot of 100 series land cruiser guys run them and the first people who started modding the GX470 first ran them. They’re basically an Old Man Emu/ ARB knockoff.
Metal tech sells a lot of them and seems to like them as they make fridges and snorkels and bumpers as well as suspensions.
If you just want a basic lift just to have a lift then it’ll do just fine. I’d spend a little more and look into King/Icon/Fox like they’re “stage 1” kits. You’ll have a better ride quality.
Thanks in advance.
I don't think I've heard much about them, but their website does have a review posted by a 4runner owner.
I've been looking for shocks with the largest diameter (cooling capability), rubber bushings (spherical bearings = reliability / wear concern), adjustable front coilovers, without remote reservoirs (extra leak points = reliability concern). These seem to be on point.
I couldn't find where they listed a warranty, but bilsteins (without remote reservoirs) I believe are 'lifetime', otherwise they are 90 days, so 3 years isn't bad.
Thanks in advance.
Did you end up getting them/thoughts?
I ran an OME on my ‘05 Liberty KJ and liked it. I’ve searched lifts For my T4R for 2 months now. There is just not much data out there on Ironman. After some investigation, I found out they are about 60 miles away in Wilsonville, OR.
I called and talked to Luke in sales on Friday for over an hour about shocks, coil springs rates, UCA, etc. Product research and design sounds legit. He owns an ‘18 T4R so was speaking from experience. Based on 95 percent on road daily use, he suggested the Nitro vs Foam Cell Pro kit. His confidence in this being a huge step up from factory and that I should save the money by not buying a more expensive kit got my attention.
For just over $1k, I’m taking the plunge on a stage 2 kit with Nitro shocks, higher spring rate ‘performance springs’, and their UCA with 4* built in caster that uses OEM ball joint and bushings. This kit was on sale from $1,500 plus they are throwing in a pair of 3” side shooter LED lights.
The price almost seems too good to be good...but there are some great reviews out there from Land Cruiser, Taco owners. Fact they are selling direct to public vs through a wholesaler and talking to a pro pushed me over the edge.
Kit should ship Monday. I plan to share more with the group on my experience good and bad on install, ride and long term experience.
Keep us posted, the more info the better, the more quality suppliers the better!
Just installed mine. Haven't uploaded pictures, but I am happy with it. Rides so nice.
My Nitro kit with performance springs is on the way. Any chance you can share:
1. What springs did you install?
2. Before and after measurements?
3. Did you install any spacers on front back or left/right for lean?
Photos are a bonus, thanks!
https://www.toyota-4runner.org/3501130-post41.html
There are the pictures:
Stock Lifted
DF: 19.5" 23.5
DR: 21” 24 1/8
PF: 19.5" 23.5"
PR: 21" 24 3/8
Hoping the front settles a little bit
Great info- this is a great reference.
Did you use comfort, performance or constant load coils?
Our starting heights are the same except I am 3/8” low on drivers front (lean)- had you compensated for that previously?
Your FCP shocks are adjustable, did you set them to factory recommended height to start??
I assume you will settle in the front or you can always adjust down.
Photos look great- thanks so much for the info!
I went with Performance Springs. I set the driver side 1/4" higher in the front to compensate for the lean. The rear I have a slight lean as well. Ironman recommended a measurement and that is where I started at.
I have been researching kits and decided on the ironman stage 2 nitro shock kit as well. I have 33in tires and they said I would have no problem bumping up the front to 3in using their forged UCA's. I would like to see some more pics when more people have that kit installed.
I preordered my kit, i should have it in a couple weeks. From what I have seen so far it looks like some people with that kit can go above 3 inches.
Why go above 3? Cv angles could be rough and youd lose alot of down travel
No I'm not trying to go above 3, it's just that I'm at 3 now with my readylift spacers and I have 33in tires that, after minor trimming, dont rub. I just dont want to upgrade my suspension and be stuck with a 2in lift and have to deal with rubbing is all. My measurement up front is just over 38in from ground to fender and would like to keep it around there.
I almost went with a OME/Bilstein combo, but with Ironman I get uca's and I save a bunch of $ with what seems to be a solid product with a 3yr warranty.
Exactly what I was considering too. My Nitro kit with performance springs should be here soon. If it helps anyone, below are my current center hub to fender measurements:
DF 19.5
PF 19.875
DR 21.625
PR 21.75
After conversation with several Ironman gents, I confirmed T4R springs are same length, not L/R specific. I’m having them preassemble my coils with one 5mm spacer on DF that should equate to 10mm (.4”) to level the front.
Estimate for a stock TRD ORP with sliders is that performance springs should give me 2.5” lift. If all goes to plan, I hope for 2.9” DF and 2.5” on the rest.
Forged UCA’s combined with my OEM wheels should yield good clearance for 285’s. I will report back as it comes together.
Need a little clarification on the spring ratings. I noticed for the front springs constant load is rated up to 220lbs, currently with bumper, skids, sliders and various accessories im pushing an additional 430+lbs overstock. Will the constant load in the front be sufficient? As for the rear I dont have much weight (less that 660lbs+ the constant load calls for). In this instance would it be best to have constant load springs in the front and performance springs in the rear?
Cheers!
Cheers!
You can email them or get on their live chat they are super helpful. But you can mix and match the coils between front and rear depending on what you are running.
Philthyphilthy
