Tucson Mike
I have a 2000 4runner. Started noticing that the rear axle is leaking. I caught the leak before it ruin the brakes. Before I removed the axle from the housing, I checked to see if it had any play and it did not. Very tight. Once I removed the axle from the housing, I tried to see if I could move the backing plate up and down (rock it). It does move up or down, so I'm thinking that the wheel bearing is bad even though when it is installed in the housing there is no play. Is this a correct assumption, or is it normal to be able to move the backing plate up and down (tilt or rock it back and forth)? Don't really want to buy new bearings/spacers/etc. if I don't have to.
Mm
Mm
