Is the erratic VSC Trac warning light associated with erratic Brake Light Switch
jow
1. Is the erratic VSC Trac warning light associated with erratic Brake Light Switch (causing resistance to shift gears)? A mechanic pulled the switch and operated it by hand and it was erratic as could be On/Off. The VSC Trac light has been just as erratic On/Off.
2. Are they related as indicating the switch that appeared to have a sticking spot in it?
3. A switch can be order at our local O’Reilly’s (approx 33.00 or 22.00) or is it best to get it from a Dealer?
4. It is to be a simple twist to remove and install. Can someone share a link to steps on 07 SR5 V6 2WD? My concern is "how much contact" before I twist to lock. "Should the battery be disconnected" during what looked simple?
5. Would this be covered in a downloaded manual if they are still available? Is it best to download to a Thumb Drive for moving and sharing?
Thanks! I miss my 1968 VW’s Technology and Service.
seltzernator
